Old 05-19-2025, 02:05 PM   #1
35 Ford 5 window
Default 59 ab into 35 coupe
Hello.
First post.
Searched many past posts but did not see the answer.
Putting a 59 ab motor out of a 49 ford coupe into my 35 5 window coupe.
Will that oil pan work?
All stock suspension in the 35.
I have the mercy water pumps already from speedway.
Going to order the new clutch kit also as I am using the 35 transmission for now.
Thanks for the help in advance.
35 Ford 5 window is offline   Reply With Quote
Old 05-19-2025, 05:59 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 59 ab into 35 coupe
Are you sure it’s a 59A and not an 8BA ? 49 Fords had 8BA engines so if you do have an 8BA you’ll need a truck pan or even better a Mercury pan. The 59A should already have a rear sump pan.
Old 05-20-2025, 02:19 AM   #3
deuce lover
deuce lover's Avatar
What water pumps did you order from Speedway ?
Old 05-20-2025, 05:54 AM   #4
corvette8n
corvette8n's Avatar
You may want to go to this link and identify your motor before you think about the swap. http://www.vanpeltsales.com/FH_web/f...ifications.htm
Lots of good info here.
Old 05-20-2025, 06:12 AM   #5
glennpm
glennpm's Avatar
Page #221 of https://www.dropbox.com/home?preview...thead+Ford.pdf; an entire section on engine identification.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 05-20-2025, 10:54 AM   #6
petehoovie
petehoovie's Avatar
Old Yesterday, 02:17 AM   #7
35 Ford 5 window
The Mercury units.
Also have the bellhousing adapter.
Old Yesterday, 02:23 AM   #8
ford38v8
ford38v8's Avatar
Do you know for a fact that you need the bell adapter? 59A needs no adapter. What distributor do you have? Pics are worth a thousand words.
EDIT: OP POSTED TWO IDENTICAL POSTS. IGNORE THIS ONE SO IT WILL GO AWAY!
Alan
