Old 07-08-2025, 09:21 AM   #1
RalphG
RalphG's Avatar
Default Spark Plug Wires
Plug wires on the 52 Merc date to the 1960s at least and are the solid core wire type. If I was to consider replacing them would it be better to go with carbon fibre or try to keep the original style? These wires put out a tremendous amount of interference on am radios and the older type tvs yet are not visibly damaged.
RalphG is offline   Reply With Quote
Old 07-08-2025, 09:35 AM   #2
corvette8n
corvette8n's Avatar
Default Re: Spark Plug Wires
I guess the question would be how often do you listen to the radio or watch tv with the Merc running nearby?, I’d probably go with the wire thats most original.
Old 07-08-2025, 09:41 AM   #3
RalphG
RalphG's Avatar
Interesting side note on that. Back in the sixties when we'd ride in the Merc to visit Grandma in town the neighbour across the street used to say he always knew when my dad was driving up in the Merc by the lines on his tv screen.
I'm still running those same spark plugs and wires today.
Old 07-08-2025, 10:35 AM   #4
19Fordy
19Fordy's Avatar
If you don't mind the static, keep the solid wires.
Old 07-08-2025, 11:47 AM   #5
tubman
tubman's Avatar
One thing I've found that if you run solid wires, replacing the coil to distributor wire with a piece of suppression wire helps a lot with interference. Every spark impulse goes through the suppression wire, but the long runs to the plugs are unimpeded by extra resistance.
Old 07-08-2025, 12:24 PM   #6
ford38v8
ford38v8's Avatar
Where else are you going to find that old classic static these days? Keep the static for the memories it brings.
Alan
ford38v8 is online now   Reply With Quote
Old 07-08-2025, 02:12 PM   #7
Ronnieroadster
Ronnieroadster's Avatar
If your car is still 6 volt running any type of suppression wire is not a very good idea from what I have experienced in the past. Carbon fiber suppression wire works great with 12 volts for sure. But at six volts the actual spark potential compared to the original style solid core type plug wires may be reduced.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 07-08-2025, 07:56 PM   #8
RalphG
RalphG's Avatar
Thanks for the replies. Sounds like I'll stay with steel core wires if I do change any. What I needed most was a new end on the coil wire where it plugs into the distributor. I was able to salvage one off a old wire today and attached it. Should be good.
Old 07-08-2025, 08:18 PM   #9
tubman
tubman's Avatar
Ralph, in case you missed my post, changing just the coil wire to suppression wire really helps with AM interference. Try it; it's easy and cheap, and works.
Old 07-08-2025, 11:13 PM   #10
RalphG
RalphG's Avatar
Thanks. I'll give that a try if I can find one to experiment with.
Old 07-09-2025, 07:21 AM   #11
fredM
fredM's Avatar
Not only neighbor's televison sets, but while sitting at red lights or when a car passes you, their radios will have static too. Not many folks will know why though.
fredM is offline   Reply With Quote
Old 07-09-2025, 07:58 PM   #12
alchemy
alchemy's Avatar
I put a set of parts store suppression core wires on when I needed them in a hurry. Didn’t really make it run horribly. But when I replaced those with a hand made set of solid core wires, the difference was enough to feel it in my seat. This is on a 12 volt flathead with a crab cap distributor. I don’t have a radio so can’t hear any static.
alchemy is offline   Reply With Quote
Old 07-09-2025, 08:12 PM   #13
ford38v8
ford38v8's Avatar
Now, that right there is more than enough reason to get rid of any suppression wires you may now have!
Alan
Old 07-11-2025, 08:46 AM   #14
GB SISSON
GB SISSON's Avatar
I think that static escaping from my solid wires must be good for my pacemaker as I always feel recharged after driving one of my old fords.
Old 07-11-2025, 08:57 AM   #15
sidevalve8ba
sidevalve8ba's Avatar
I'd rather listen to a lightly muffled flathead than a radio any day!
sidevalve8ba is offline   Reply With Quote
Old 07-11-2025, 09:29 AM   #16
RalphG
RalphG's Avatar
This Merc is straight piped to the rear bumper and surprisingly quiet unless my foot gets too heavy. Idling around town it sounds quite acceptable.
Old 07-11-2025, 09:30 AM   #17
Drbrown
Drbrown's Avatar
Copper wires are best for performance as they present less resitance to the spark transmission than carbon core or carbon core spiral wound wires. Its worth noting that most electronic distributers recomend the latter types as copper wires put out a signal that interfers with the distributer function.
Drbrown is offline   Reply With Quote
Old 07-11-2025, 06:23 PM   #18
18tillidie
18tillidie's Avatar
Where do I buy me a set of spark plugs and leads nowadays that will last me 60 years???
18tillidie is offline   Reply With Quote
Old 07-11-2025, 06:55 PM   #19
tubman
tubman's Avatar
Some Packard 440 and Rajah terminals from "The Brillman Company" should take care of the plug leads part of it. You're on your own with the plugs. (Hint; it is not those triple electrode things from J.C. Whitney.) And I already looked; they don't make iridium plugs to fit flatheads.
Old 07-11-2025, 07:21 PM   #20
34fordy
34fordy's Avatar
When I was dating my wife in 1964 my father-in-law said he could tell when I was coming as the TV went whaco. They lived on a farm about 3/4 of a mile from the highway. Probably gave him time to load his shotgun. LOL. He actually liked the dumb kid from town!
34fordy is offline   Reply With Quote
