Old 08-03-2025, 07:46 AM   #1
spinelll
spinelll's Avatar
Default Coolant Temp Saga
I took some infrared measurements yesterday after a short drive and while idling.
Coolant - 185
Tank top - 185
Tank bottom - 175
Return pipe - 175
Block - 185
I also noticed foam while idling (attached). It disappeared shortly after shutting down.
I'm gonna take the radiator to a shop. Are the Les Andrews steps to remove a radiator accurate?
Thanks
Leo
spinelll is offline   Reply With Quote
Old 08-03-2025, 08:25 AM   #2
Ordsgt
Ordsgt's Avatar
Default Re: Coolant Temp Saga
Before you remove the radiator I would do a compression check on all cylinders. That "foam" may be indicative of a head gasket leak.
Ordsgt is offline   Reply With Quote
Old 08-03-2025, 09:03 AM   #3
nkaminar
nkaminar's Avatar
Foam does not cool very well and may be the cause of your higher than normal temperatures. There are various things that can go in the radiator that will generate foam. Some antifreeze solutions can foam.
Drain the radiator and engine block. Add fresh water and run the car for a few miles. Drain again and repeat the rinse until there is no sign of any additions to the the water.
Drain a final time and add 50/50 antifreeze/water pre-mixed mixture up to the level of the baffle in the bottom of the top tank in the radiator. Get the antifreeze mixture that is recommended for older cars. It is usually green. See if this cures the foaming problem.
Old 08-03-2025, 09:09 AM   #4
Big hammer
Some antifreeze will foam ! Drain it out , fill with water, repeat your test
get a bigger hammer tap done
Old 08-03-2025, 09:10 AM   #5
Richard Knight
If your radiator is only dropping the temp of the water 10 degrees it is not working. There should be a drop of 20-30 degrees. Measure the temp of the cylinders below the water jacket. Also the top of the head on the number 4 cylinder. The compression test will tell you if you have a leaky head gasket.
Richard Knight is offline   Reply With Quote
Old 08-03-2025, 09:32 AM   #6
katy
katy's Avatar
Are you running a thermostat?
Old 08-03-2025, 09:34 AM   #7
spinelll
spinelll's Avatar
This is what I've been using for a few years.
Old 08-03-2025, 11:59 AM   #8
TMarsh
I agree with posts 3 and 4, happened to me. I like green Prestone, yellow jug 50/50
TMarsh is offline   Reply With Quote
Old 08-04-2025, 09:24 AM   #9
spinelll
spinelll's Avatar
I am not.
