I have several Starrett precision machinist tools and know how to use most of them, but I'm a little shaky about how to interpret and use this drill gauge. Any guidance would be appreciated.
I think it’s two different things stuck together. Right side is a sizing gauge to tell you what gauge a wire is and the decimal equivalent in inches. Left side tells you what size body drill bit and tap drill bit to use to tap a given thread pitch and size. The body drill bit is the one used to remove most of the stock, then you finalize the hole with the tap drill bit, then you tap the hole.
It’s confusing because your instinct is that the two sides should connect but I don’t think they do, it’s just two useful things on the same sheet of metal. |
#3 | |
![]() Quote:
Here’s the modern version of your drill and wire gage. Still available from Starrett. Link. https://www.starrett.com/details?cat-no=185 Last edited by AzBob; 07-25-2025 at 11:46 PM. |
