Who makes the floats that slide over the arm where the original cork float was secured?
Alan, I do not recall having ever seen a replacement cork float. I believe you'd be best served by using a brass float. If your arm won't accept the brass type, let me know and I can send you the arm for the brass float.
Easy enough to swap arms.
#3 | |
![]() Quote:
![]() ![]() GAUGE FLOAT ONLY Part # A-9313-C | Model Year 28-31 Made from modern material that is resistant to today's ethanol in fuels. The last float you'll ever need to buy! Replace it once and forget about it. Dimensions - 1 1/8" x 1 3/8" long Also, see this thread > https://www.fordbarn.com/forum/showt...ght=cork+float Last edited by petehoovie; 08-06-2025 at 11:41 PM. |
Wow! Thanks Pete!
I believe that material is "nitrophyl",I replaced the float in my '37 several years ago with it. Works great!
Tom |
#7 | |
![]() Quote:
![]() https://rogerscorp.com/Elastomer%20Components/NITROPHYL |
Thanks Pete
