Old 06-20-2025, 12:33 PM   #1
Tom F OHIO
Tom F OHIO's Avatar
Default Oil
I have a new to me a 51 ford v8 and was wondering what brand oil and weight I should use. Thanks for the help...
Tom F OHIO is offline   Reply With Quote
Old 06-20-2025, 01:15 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Oil
You’re about to get 100 different answers but I have used Shell Rotella 15W40 for 50+ years in my own 36 stock engine I have built many flatheads to include hot rod stroker flatheads and I use the same oil in all of them. Never an issue. That’s my 2 cents of real life experience. Enjoy.
Cheers
Tony
KiWinUS is online now   Reply With Quote
Old 06-20-2025, 02:45 PM   #3
cas3
Default Re: Oil
Oil is good, I use it in all my engines
Old 06-20-2025, 02:57 PM   #4
tubman
tubman's Avatar
Default Re: Oil
One caveat (though it should not be necessary). Do not, under any circumstances, let some all-knowing "old-timer" talk you into using non-detergent oil.
Old 06-20-2025, 03:42 PM   #5
Tim Ayers
Default Re: Oil
Agreed.
Old 06-20-2025, 03:50 PM   #6
glennpm
glennpm's Avatar
Default Re: Oil
Cheers
Tony
Same here ...
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 06-20-2025, 05:27 PM   #7
Flathead Fever
Flathead Fever's Avatar
Default Re: Oil
Second me on the Shell 15W-40W diesel oil. Because of the extra strains put on diesel engines this oil still has the anti-wear additives that used to be in all oil. I worked as a mechanic for the phone company, and we had around 400 vehicles. We only stocked one kind of oil, it was Chevron 15W-40W diesel oil, we ran it everything, good stuff.
Old 06-20-2025, 07:12 PM   #8
aussie merc
aussie merc's Avatar
Default Re: Oil
any quality oil will work remember that the worst oil today is probably better than the best oil back then personally im with a quality 15/40 diesel oil
aussie merc is offline   Reply With Quote
Old 06-20-2025, 07:20 PM   #9
leon bee
Default Re: Oil
NAPA conventional 10w30 in my newer tight engine.
NAPA conventional 20w50 in my loose engine.
leon bee is offline   Reply With Quote
