How are the upholstery door panel ratchet nails removed for the pickups ? Should the grommet and nail be removed as a unit ? The vendors sell these to replace the originals that were mounted in metal retainers no longer available.
Shortly thereafter I managed to crack the drivers door window.... Could not get those ratchet nails out, no matter what..... So I cut a length of brass tubing, and made sort of a hole saw that would fit over the head of the nails. Then I was able to cut around the nail to remove the panel without further damage, and then I cut each nail head off and pushed it through the retainer to remove the nail. When the time came to reinstall the door panel, I bought small black phillips screws and upholstery cup washers and used the screw/washer set to reinstall the panel, running the screws into the nylon nail retainers. The washer was large enough to completely cover the hole. Not original, but it looks OK. It would seem that once those nails are in, they are in to stay.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 05-31-2025 at 01:37 PM. |
