Old 05-13-2025, 08:20 AM   #1
markdtn
markdtn's Avatar
Default Flathead alternator conversion-Ford alternator?
I have an 8BA in a 2N Ford tractor. It has a 63A 10si Delco alternator (high amps needed for a Taurus electric fan-no room for a mechanical fan). I'm in the process of putting the engine in an 8N tractor so while it is exposed and I have to rewire it anyway I thought about using a Ford 3G alternator instead of the Delco to be all Ford. I see that the mounting holes on a small case 3G are closer to 7" spacing instead of 6 5/8" but other than that I don't see why I couldn't do it. Anybody else put a Ford 3G (or 4G) alternator on a flathead instead of the Delco 10/12si? I know I could probably put an earlier Ford alternator but I like the internal regulator to keep things clean looking. I would wire it with a charge light and a voltmeter.
markdtn is offline   Reply With Quote
Old 05-13-2025, 09:32 AM   #2
cas3
Default Re: Flathead alternator conversion-Ford alternator?
I always loved those tractors with a v8! I don't think most folks could tell what kind of alternator is on there, I'd just do whats easiest
cas3 is online now   Reply With Quote
Old 05-13-2025, 09:58 AM   #3
markdtn
markdtn's Avatar
No, you are correct, it's hard to tell what alternator is on there with the hood on. The 10si 1-wire Delco conversions are very commonplace on a lot of cars, tractors, and equipment. Because they are easy, available, and cheap. And I will say this, I am a hard core GM guy, but it has always bothered me a little that I had a GM alternator on a Ford. I don't know why, it just does. It has a Taurus fan, so that is Ford. It has a Volvo 2-speed fan relay so you can stretch and that was Ford. It has a BMW fan switch/sending unit that really fits the bill for 2-speed electric fan control. There is nothing out there like it for that switch so I squint and ignore that. But the alternator could be Ford I think. I have found that '91-96 Escorts used a small case 3G style alternator that is 75A output. I may try to find one and try it. Best I can tell the center part of the alternator is 5mm larger radius-so like 3/16". I think the bracket will accommodate that. I would just have to slot the mounting holes and it should bolt up. I have a wide belt pulley for the Delco that I THINK will bolt onto a 3G. If not, those are out there. I know this is not traditional Flathead stuff, but I thought maybe there was a die-hard Ford guy (or gal) out there that needed an alternator for their application and would not have GM stuff on their Ford. Either way I am wiring it 3 wire this time because I don't like to have to rev it cold to make it start charging. Thanks!
Old 05-15-2025, 05:08 PM   #4
Gene1949
Gene1949's Avatar
Pretty much my setup. Bought aftermarket thermal switches and mounted the in the bottom tank next to the outlets. Thermostats regulate engine temp and there is no sense running the fan if the radiator is managing the heat load.
Used a '97 SVO alternator (130 amp I think). I also wanted to use the sensing wire, just like Ford intended. IF it was cheaper to run a single wire setup Ford would have done it. I also ran the smallest diameter pully I could find. Given the low RPMs our motors are used, made sense to spin it faster at low speed.
Gene1949 is offline   Reply With Quote
Old 05-15-2025, 05:42 PM   #5
Flathead Fever
Flathead Fever's Avatar
I have three of those 8N tractors One I rebuilt the engine 40 years ago and the engine and generator are still going strong. I had the one and then I bought two more dirt cheap, not running. The engines run something else in the transmission broke/ I paid $500.00 for each of them. Nice sheet metal on them. I'd thought I'd do something with them but then I had stroke. Both of those have alternators on them. I finally bought a Kubota with a bucket and now the 8Ns are yard art. The 8N's are great tractors for discing but the ground is so hard here and so full of big rocks I had to upgrade to the Kubota.
