Old 05-14-2025, 06:45 PM   #1
oldford
Default How to remove 32 choke cable
The cable at the end is to big to go thru the small hole in the dash. I'm thinking the parts of the cable at the end come off but can not figure how to remove them, assuming that is the way to remove cable.
oldford is offline   Reply With Quote
Old 05-14-2025, 08:10 PM   #2
DavidG
DavidG's Avatar
Default Re: How to remove 32 choke cable
Once you have removed the cable from the carburetor, lift the sleeve that is on the carburetor end to reveal a small split retaining ring. Remove the ring and the sleeve and large outer spring will come right off the cable.
Old 05-15-2025, 12:01 PM   #3
37 Coupe
37 Coupe's Avatar
Originally Posted by oldford View Post
No it will not. The end of the cable that has that flat bar on it needs to come off and it is pressed on. I removed the split ring and all I accomplish was to break it. Are there any 32 guys out there,
I just did this same thing that David posted two weeks ago. I wanted to position the choke cable and knob the right way that a Model B should have on the dash,someone before me placed choke knob and dash light switch in V8 position for some reason. You can get a new split ring from David Renner online Renners Corner. You will probably have to remove a couple other parts that go in same firewall hole at first to make room for removal like the vacuum tube for wiper and use a split grommet to replace for all that goes in there, speedo cable ,fuel guage line ,choke cable ,vacuum tube.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 05-15-2025, 12:06 PM   #4
glennpm
glennpm's Avatar
Here is a picture of a 32 choke cable with the carb end disconnected. You can see the small snap ring too. It can be purchased here, https://www.rennerscorner.com/choke-cables.html
Besides not thanking David for helping you, you insult him. He is the most knowledgeable '32 guy anywhere and extremely helpful too.
"You don't tug on Superman's cape" :-)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
Old 05-15-2025, 12:08 PM   #5
fastone371
Your wife says Tower of Terror, but Disney says the Chinese Theatre. Honestly, this park's had more identity crises than a soap opera character.
fastone371 is offline   Reply With Quote
Old 05-15-2025, 12:11 PM   #6
glennpm
glennpm's Avatar
Multy tasking on the web?
Rumble Seat's Notes
Old 05-15-2025, 02:33 PM   #7
Ryan
Administrator
Ryan's Avatar
A reminder fellas… manners matter. Please don’t post like a modern day politician or I will close your account.
Thanks.
Ryan Cochran*
- www.AtomicIndustry.com
Ryan is offline   Reply With Quote
