Old 03-26-2025, 07:16 PM   #1
Willie S.
Default 1950 Mercury Flathead
Hi, I’m looking for an oil dipstick for a 1950 Mercury Flathead engine with a rear sump oil pan. A Ford dipstick will not work as it’s shorter, 18 1/2 in. Whereas I need the Mercury dipstick which is 19 5/8 in. I’ve looked everywhere on the internet plus made many phone calls and i am running out of options. Any help would be greatly appreciated.
Willie S. is offline   Reply With Quote
Old 03-26-2025, 07:21 PM   #2
paul2748
paul2748's Avatar
Default Re: 1950 Mercury Flathead
If it's any help, the dipsticks for 55-57 Tbird and Yblock trucks were long. I know it will not be marked correctly, but you can remark it yourself. Option if you call does not come up with something. Not sure if the little cap on the top will fit the tube though. The TBird ones are available aftermarket from the TBird part suppliers.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-27-2025, 10:30 AM   #3
Willie S.
Thanks for the information but the Mercury Flathead dipstick tube is rather large and will not support those dipsticks.
Old 03-27-2025, 01:28 PM   #4
Ggmac
Can you cut the Mercury tube shorter and use the dipstick available? Or weld and extension on to the shorter stick . The thread is 1/2-20 if I remember correct.
Old 03-28-2025, 07:02 PM   #5
pbsdaddy
pbsdaddy's Avatar
Where are your from? Carlisle is coming up in less than a month. I would be money one can be found there.
pbsdaddy is offline   Reply With Quote
Old 03-29-2025, 01:35 AM   #6
69a
All the dipstick castings on the side of the oil pan (to my knowledge) are mounted at the same height. Approximately 2 1/8" from the bottom of the pan rail to the top rivet.
I'm sure you can use any flathead dipstick that is long enough to get wet.
So measure the length that the dipstick tube extends from that casting. Add 4 7/8" to that length and mark that as "FULL" now put a smaller mark 5/8" below it. The smaller mark is "ONE QUART LOW", this allows you to easily calculate how much to add when topping up.
Just to make this clear the oil level when measured at the 45 degree angle of the dipstick tube, is 4 7/8" below where the dipstick tube enters the casting.
69a is offline   Reply With Quote
Old 04-27-2025, 04:10 PM   #7
Willie S.
[QUOTE=Ggmac;2379288]Can you cut the Mercury tube shorter and use the dipstick available? Or weld and extension on to the shorter stick . The thread is 1/2-20 if I remember correct.
Old 04-27-2025, 04:15 PM   #8
Willie S.
I bought two 1950 Ford flathead dipsticks, I’m going to cut them both and weld a 1 5/8 to one, that’ll make one 19 1/2 inches . Which is the length I need. Thanks.
Old 04-27-2025, 07:18 PM   #9
19Fordy
19Fordy's Avatar
Willie: Here's some helpful info. on the OEM genuine Merc. dipstick that came with my 1949-50 Merc. rear sump oil pan. Correct OEM measurements are shown. Dipstick has the letter "M" stamped on it.
https://www.fordbarn.com/forum/showt...rcury+dipstick
19Fordy is online now   Reply With Quote
