Old 04-23-2025, 11:31 AM   #1
jchochole
jchochole's Avatar
Default 1934 Ford M40 No Spark
I have a '34 M40 that ran about 5 months ago (for prev owner) but now has no spark. Starter turns and distributor looks clean and newer, but wanted to ask if anyone has tried to add the 6v coil kit to an external coil.
The car has sapped most of my funds thus far and can't really afford to get a full dizzy rebuild at this point. My goal is to get it running by any means to be able to move the car around.
Thanks,
Jim
So, I have a yellow 6v hot wire from the ignition but when I connect to the brown dizzy wire the voltage drops to 1.4. Not sure why.
"Whether you think you can, or think you can't- you're right." H. Ford
jchochole is offline   Reply With Quote
Old 04-23-2025, 11:37 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 1934 Ford M40 No Spark
Is there a EFV8 Club Regional group close to you? Members there would be a great resource for you...
Old 04-23-2025, 11:45 AM   #3
jchochole
jchochole's Avatar
I reached out.
Old 04-23-2025, 01:51 PM   #4
Kens 36
Kens 36's Avatar
Just sent a response from RG#8 a few minutes ago. We will try to help him.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 04-23-2025, 02:32 PM   #5
cas3
Clean the points
Old 04-23-2025, 03:24 PM   #6
petehoovie
petehoovie's Avatar
Thanks,
Jim
Old 04-24-2025, 06:44 AM   #7
Terry,OH
Terry,OH's Avatar
There is a ignition resistor mounted to the inside firewall above the steering column. The resistor drops the voltage to the ignition coil. Usually to about 4V at the coil terminal but you can only read this voltage drop when the distributor points are closed and ignition switch is ON. When the ignition is ON and the distributor points are open you should have battery voltage on the coil terminal. There are several reasons the voltage is low. Bad battery, Poor wire and cable connections, dirty or pitted ignition switch, bad coil, bad condenser, bad resistor.
