Old 03-17-2025, 02:53 PM   #1
37 Coupe
37 Coupe's Avatar
Default Model B stop light switch wiring feed routing.
So I just finished installing a complete wiring harness from Rhode Island wiring and pretty easy except for one area.I just want to make sure the correct routing from where the two switch wires leave frame rail area to over or under pedal linkage safely. It looks to me that it would clear all the movement underneath but need to make sure,otherwise everything else was easy and straight forward.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 03-17-2025, 05:06 PM   #2
DavidG
DavidG's Avatar
Default Re: Model B stop light switch wiring feed routing.
Please see page A13-2 for a view of the B-9294 clip that is attached to the left leg of the K member to help keep those two wires from getting too close to the pedals or their grease fittings.
Old 03-17-2025, 05:40 PM   #3
37 Coupe
37 Coupe's Avatar
Got it,explains it all .
Thank You.
Old 03-18-2025, 01:52 AM   #4
DavidG
DavidG's Avatar
You're welcome.
