I have a '54 Mercury parts car with an original 256 c.i. in it. The motor turns over with a ratchet but not a full revolution. Something is broken inside, perhaps a rod or something. Is there any good reason to keep it or should I let my grandson tear it down out of curiosity and then junk when he's done?
could be just a stuck valve.
Depending on your grandson's mechanical curiosity, might be a great project to do together...you get to teach him some of your skills, and he gets to build some memories with you!!
That's kinda where I'm heading. Just don't want to junk something of value to someone else before I turn him loose.
So, suppose the point of the project was to find out what is wrong with it and talk about the options/cost to fix it vs. junk it?? At that point all you have in it is time.
Consequently, they are mostly of interest of a restoration rather than a driver. As marco points out a stuck valve isn’t uncommon. Pull the valve covers, loosen the valve settings, and see if it pulls thru. If you’ve got a hoist and an engine stand, I’d put it on the stand and pull the pan. And maybe the heads. I use the hoist to support the engine even on the stand when I can. Yblocks are heavy, and a grandson needs guidance and protection from what he doesn’t know. From there you can decide if you want to pull a head. Might even have a look with the borescope just for laughs. |
