My replacement pilot bearing is thicker than the surface in the flywheel it's made to be located on. I want the bearing to be in the right location to correctly support the end of the main drive gear. What would be the best position to use? 1) I can press it in place so it's centered on the surface it mounts on, and overhangs a small amount on both sides or 2) install it flush with the front face or rear face of the flywheel where it mounts, and overhanging on the opposite side. We're no talking a big difference in location, but I'd like to do it right.
Any information would be appreciated. Thanks. |
#2 | |
![]() Quote:
Good question, welcome to the forum.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! Last edited by JayJay; 01-19-2025 at 12:44 AM. |
Paintshaker, welcome to the forum.
JayJay,
Thanks for the very clear explanation. I was able to find a cross sectional drawing of the clutch area and I see just what you mean. There is really no choice. The bearing has to be positioned as you said or the crankshaft flange would run into it when the flywheel is being installed. Thanks very much for your help. |
old31,
Thanks for the greeting. I'm sure the forum is going to be a great resource. It's nice to be getting into model A's again. |
#6 | |
And when you are installing the clutch, I find that the plastic pilot tool doesn’t help much to align the friction disc. I find I need a real tranny input shaft. Having the engine nose down and the flywheel parallel to the ground will help. Admittedly kinda hard to do this with the engine in the car, though…
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
The plastic 1 3/8"-10-spline tool isn't the best. The old conical alignment tools were better but not common now days. It takes patience to align the clutches on the rimmed flywheel design.
I got into all of this to replace my main drive gear. I plan to use the replacement part as my pilot.
I'm just now getting back into Model A's. Any recommendations on what supplier to use for a complicated part such as this? I don't mind paying for quality. I want to get the best part possible. I'd prefer not to have to do this job over again. |
Pretty much these days all the suppliers draw from the same limited pool of manufacturers. Fortunately, the gear manufacturers appear to be of pretty decent quality, even if overseas (I bought a steering sector shaft recently and it came from somewhere in South America!). You can call the suppliers for the specific gear you are looking for and ask them where they source the part. Any of the Model A suppliers - Snyder's, Bert's, Bratton's, Arizona Model A, Smith & Jones are some that I've dealt with - should be able to accommodate you. Some of the replacement transmission bearings can be sort of iffy, search on this forum for the many discussions we've had on that topic.
At the extreme, if you are looking at having to replace a bunch of parts in your transmission, you might consider a Mitchell transmission. All new internals, synchromesh 2nd and 3rd, strong tower, gears made in the good old US of A.
Thanks once again for the information you've given me. You've been very helpful. You mention searching on the forum. I'm going to have to try a little harder to find details on how to navigate around on the forum. There has to be an easier way to find stuff. Right now I just wander around a lot, even to find my own post. The forum looks like it could be a great resource, now I have to figure out how to tap into it.
I have learned how to do a search. What a fantastic tool! There's an amazing amount of information at your fingertips.
