Old 04-15-2024, 02:08 PM   #1
91A-77B
Default 1937 Cad/LaSalle Trans
Looking for assembly/disassembly instructions for the internals. Hooking it up to 59A. I have the adapter. It's a bottom-loader, tough to work on. Help appreciated.
91A-77B is offline   Reply With Quote
Old 04-15-2024, 04:20 PM   #2
jimTN
Default Re: 1937 Cad/LaSalle Trans
you will have more fun than you can imagine on a key snap ring in there. I had to use a welding tip to get in the middle. Maybe someone can give a easier method.
Old 04-16-2024, 09:06 AM   #3
tetanus
there was a good writeup on the hamb a guy did. had lots of pics too. it was a side shift but should help.
tetanus is offline   Reply With Quote
Old 04-16-2024, 09:10 AM   #4
tetanus
https://www.jalopyjournal.com/forum/...lshaft.185196/
Old 04-16-2024, 10:52 AM   #5
91A-77B
Many thanks, tetanus. I'll print the link. I have a floorshift '37 with the Olds tailshaft. but missing some parts of main drivetrain. Also have later sideshift with long tail for parts. How about the synchros in these trans! Bulletproof. No wonder they were the dragsters' favorites in the old days. Anybody have further info about the one-year-only '37s with bottom-load?
Old 04-16-2024, 02:46 PM   #6
40coe
40coe's Avatar
Does anyone know a machine shop that could shorten a Lasell main shaft and cut the Ford spline on it for the Ford U joint?
I am wanting to use the Ford torque tube set up.
40coe is offline   Reply With Quote
Old 04-16-2024, 06:48 PM   #7
rich b
rich b's Avatar
Sometime in the past Brian Bass had posted about cutting splines.
http://www.basskustom.com/
Old 04-21-2024, 12:22 PM   #8
40coe
40coe's Avatar
I have a lead on a 1950's Oldsmobile side shift transmission. Same internals as the Lasell but the tail shaft is much shorter. If interested let me know via pm or post, and I will forward you the guy's information that has it for sale.
Old 04-21-2024, 02:30 PM   #9
Ronnieroadster
Ronnieroadster's Avatar
When I first built my Deuce roadster with a health flathead I knew the Ford three speeds would never hold up to my abuse. So I used the 37 Cad/LaSalle floor shift bottom loading transmission. The trans held up perfectly.
However there was only one problem I experienced. When power shifting hard one day from 1st to 2nd I broke the shifter. What caused this was of course my abuse and the weak link I discovered. This weak link is where the upper selector pin is pressed into the shifter stem. With the shifter broken the transmission remains in 2nd and now there's no way to change gears or go into neutral.
Since the case was a bottom loader it was easy but of course messy to get the now broken off lower part of the shifter and pin out of the gear box. The break was located dead center at the hole for the selector pin. The repair was actually very easy I simply welded the shifter stem back together with my AC stick welder I did not weld the pin at all it fit back into the hole fine.
The next time I broke the shifter more power shifting I repeated the above but this time added a lot more weld simply building up the shifter at the weak point and now it never came apart again.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 04-21-2024, 02:41 PM   #10
Biggles
Biggles's Avatar
Yes, that second gear snap ring is a ba***rd. When you get it off, throw it into the far distance, long grass, and replace it with a C-ring.
The rear main bearing is a New Dimension unique item. Unobtainium. Take care.
Biggles is offline   Reply With Quote
Old 12-06-2024, 09:33 AM   #11
hotdamn
Hotrod Williehas had a few of them made, you can find them for sale in the HAMB classifieds. Willie is a good guy and the shafts he has for sale are very nice, one of my best friends just bought one and was very happy with it.
hotdamn is offline   Reply With Quote
Old 12-06-2024, 01:53 PM   #12
Karl Wolf
Karl Wolf's Avatar
Call Mitchell Overdrive, they cut splines for me 20+ years ago.
Had to wait for them to set up machinery for another run, but not a long wait.
Way more reasonable than other places.
AND, as they do this often, it was done correctly.
Karl
Karl Wolf is offline   Reply With Quote
