I'm new to owning a Model A,and I've got a few questions like what size inserts would I need or how to measure for the insert.Or are am I looking at it wrong and they are babbets?
Should be babbitt if it's still stock Ford.
What problem are you trying to cure?
Crank and connecting rod journals are poured babbitt. Many times they can be adjusted by removal of the cap shims but it depends on condition of each bearing assembly. There are still folks that re-pour babbitt and machine it for best fit. There are also conversions for removable bearing shells but it takes machine work to do that.
New Burtz blocks are available as an alternative to overhaul. |
Tony, if this is your first adventure into owning a Model A, I think you’re reaching in too Deep. Tampering with the engine takes a lot of experience, knowledge, money, and special tools. "Go slowly for a more harmonious outcome." :::Old Soiux saying.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
Are you currently having a knock, or noise or is the engine not running? |
If you already have the engine opened up please send some pictures.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
Tony, where are you located?
Sorry I just found out how to post pics
Sorry I just found out how to post pictures
Cocoa Florida
You have Babbitt bearings that have failed or are about to fail. There are +/- to each bearing.
Babbitt is adjustable and forgiving of grit that gets in them and you can 'farmer' it if you absolutely have to-to get you home if you don't have a AAA card. The downside is that they must be installed correctly or they will come apart and there fewer and fewer places doing them correctly anymore. Shells-most machines shops who know about Model A motors can do them nowadays and they will last you a very long time if done right. Downside is that any grit will shred them and you will be doing a rebuild. This is the gyst of the differences of the bearings and I am sure that people smarter than me will chime in. Mike
#13 | |
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
![]() Quote:
A good machine shop will use tin base babbitt as shown in two pictures enclosed. |
#14 |
And to think our forefathers repaired these engines in primitive working areas with minimum tools.
#15 |
Tony, You should not be afraid to work on your Model A. They are very simple and a good car to learn on. Buy the redbook, link below. J & M in Post #13 is right, the bearings will need to be repoured and remachined. Best to take it somewhere. Or look around for a used engine in good condition. Or buy a Burtz Block.
https://www.snydersantiqueauto.com/p...0031&cat=41621
#16 |
![]() I was going to add: "should be thin babbitt..." but i see OP has posted pix. the broken corner dosen't bother me as much as the wafer thin babbitt... in old days they used bacon rinds in there 'tween rods, mains and the babbitt. the old timers say it worked!! you can also hand scrap in a new babbitt bearing cap. and that works, too! just have to get the running clearance correct. ![]() am thinking those mains 'groaned' noticeably under low rpm, high load conditions...
"My Model A... work never ends, only the day ends!" |
#17 | |
![]() Quote:
#18 |
They also used the tongues out of old military type boots but these "fixes" don't last very long.
As the crank is ground down to smaller under sizes, the babbitt has to be thicker and thicker. A person doing the pouring also has to know the best way to peen the babbitt before align boring to size. The babbitt tends to shrink a bit on something as large as an engine block so peeing the surfaces is important. Babbitt journal bearing re-work is an art form that takes a while to learn. It's better to find someone with a lot of experience to do these type of jobs. |
