Old 06-07-2021, 08:05 PM   #1
paul2748
paul2748's Avatar
Default KULTULZ - info on breaker plate
A guy has a distributor breaker plate for sale B7A-22151-A. Says it's for a dual point setup. Can you check?
Thanks
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-07-2021, 08:34 PM   #2
51504bat
51504bat's Avatar
Default Re: KULTULZ - info on breaker plate
could it be B7A-12151-A not B7A-22151-A?
Found this on the web:
1957 Ford and Thunderbird NOS Dual Point Distributor Breaker Plate B7A-12151-A
Old 06-07-2021, 11:30 PM   #3
dmsfrr
dmsfrr's Avatar
Here's a copy of the photo in the ad paul2748 is asking about, B7A-12151-A is on the box.
I don't have a part number book but I believe the part in the photo is for single points, not dual.
Mostly because there is only one round hole with the small screwdriver notch for gap adjustment,
and the pair of threaded screw holes for mounting a 2nd set of points is missing.
Old 06-08-2021, 12:25 AM   #4
KULTULZ
KULTULZ's Avatar
Post Re: KULTULZ - info on breaker plate
That breaker plate is the 1957-59 single plate design. FORD went to two plate design, phasing in the 1958 model run.
The one shown is getting scarce.
If you wanted dual points, usually it was a MALLORY conversion plate kit.
ADDENDUM (Fr) -
Aftermarket Dual Point Kit shown below (1957-59 Single Plate) -
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-08-2021, 08:57 PM   #5
paul2748
paul2748's Avatar
Yep 12151 - single plate or single point set??
ADDENDUM (Fr) -
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-09-2021, 12:45 AM   #6
KULTULZ
KULTULZ's Avatar
Single Plate - Single Points
The DUAL POINT CONVERSION shown was aftermarket.
The OP is either un-knowledgeable and/or shady.
Old 06-09-2021, 02:18 PM   #7
dmsfrr
dmsfrr's Avatar
There were oem Fomoco dual points plates available for '57, used in the distributors of the higher horsepower performance engines. Possibly the 285 hp E code engines as well as the supercharged F code engines.
Very hard to find and made of unobtainum, with a corresponding price.
http://www.portholeauthority.com/thu...ch/engine.html
Old 06-09-2021, 02:39 PM   #8
KULTULZ
KULTULZ's Avatar
Documentation?
Old 06-09-2021, 11:01 PM   #9
dmsfrr
dmsfrr's Avatar
Documentation?
I don't have a library of old Ford documents.
It was a conversation between a couple F-code collectors/restorers on a Y-block page on facebook... they were discussing restoring an F-code specific distributor and needing an original Fomoco dual points plate for it. (not an aftermarket reproduction)
I don't recall them posting a photo of the rusted one that needed replacement but it's possible. If I can track down a photo I'll share it.
In the meantime... a copy of a Sun Electric Corp. '57 F-code tune up spec sheet.
Notice the dwell spec is listed as 26-28.5 degrees for each set of points and 33-36 degrees when both sets are combined.
Old 06-10-2021, 06:00 AM   #10
KULTULZ
KULTULZ's Avatar
Thumbs up Re: KULTULZ - info on breaker plate
It was a conversation between a couple F-code collectors/restorers on a Y-block page on facebook... they were discussing restoring an F-code specific distributor and needing an original Fomoco dual points plate for it. (not an aftermarket a reproduction)
It seem you are correct. There is another plate listed for the 57 FORD S/C FEH-12127-E and BIRD S/C FEJ-12127-D distributors only, that PN being B7A 12151-B. It's description in the 1949/59 MPC gives no description of it as being DUAL POINTS and the listing for points (12171) shows only one set.
But you have a valid point (pun intended).
If you come across any more info, please post.
THANX! for ringing my bell.
Below is a bowl photo from a post the owner describing his 57 BIRD E-CODE 285HP as coming through with dualing points. Hard to verify after all these years.
File Type: jpg FYB - IGN - 312 E-CODE 258HP DIST PLATE.jpg (55.7 KB, 22 views)
Old 06-10-2021, 10:48 PM   #11
dmsfrr
dmsfrr's Avatar
... If I can track down a photo I'll share it. ...
I asked a couple folks I know of who are F-code owners if they could share photos of an original dual points plate. I got these two views back so far, of the same distributor.
Old 06-10-2021, 11:55 PM   #12
KULTULZ
KULTULZ's Avatar
THANX for the photos . It is a BIRD DIST (TACH)?
I would like to see how the COND is mounted to the outside of the housing.
Old 06-11-2021, 05:16 AM   #13
LOWRIDER
LOWRIDER's Avatar
I had one of those DynaFlight dual point breaker plates on my 57 Ford. I mounted the condenser on one of the vacuum advance screws. Worked fine. I ran it until I converted the ignition system to a Duraspark system.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 06-11-2021, 08:15 AM   #14
KULTULZ
KULTULZ's Avatar
THANX! for that.
What I am interested in is seeing how the OEM install was and if it took a special DIST HSG or the regular housing just received a different machining protocol.
My interests are more pure stock than modification(s).
Old 06-11-2021, 11:02 AM   #15
dmsfrr
dmsfrr's Avatar
Those photos may be the distributor for this car, sent by the owner.
It's a Phase 1 factory supercharged D/F code car, 1 of 65 made.
OEM condenser location? It was on the outside of the dist housing, likely using one of the existing screws. I'm waiting for more photos.
Old 06-11-2021, 12:55 PM   #16
V8COOPMAN
V8COOPMAN's Avatar
My God ....THAT son of a gun is FINE! Something really interesting is the red color being carried-on around the windows. I could be "SEEN" in this rig! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-11-2021, 04:03 PM   #17
KULTULZ
KULTULZ's Avatar
That's what I am interested in, the outside mounting style. PHASE 1? Might be different.
If you have a chance, see if he can give the DATE CODE off the DIST and also the DIST HSG CASTING ID NO (the Basic Part Number is 12133).
The DATE CODE will be stamped just under the DIST ID NO.
Old 06-11-2021, 04:47 PM   #18
dmsfrr
dmsfrr's Avatar
Two more photos I was sent, from an F code T-Bird owner / collector.
Photo 1.
The B7A-12151-_ part number printed on the box ends with a letter "A". The part number printed on the paper wrapper ends with a letter "B".
... There is another plate listed for the 57 FORD S/C FEH-12127-E and BIRD S/C FEJ-12127-D distributors only, that PN being B7A 12151-B. ...
The lettering stamped into the plate is:
upper left, "MADE IN U.S.A."
across the bottom: "NEW DEPARTURE". (a 'replacement parts' mfr?)
upper right: "900600" or "009006".
The metal finish is a silver color, not black as I'd expect based on seeing a few other oem '57 points plates.
When zoomed in on the original photo... the left side of the plate appears as if it may have been modified from original. The quality of the metal work isn't the same as on the right side, and there looks to be an extra screw hole left over from the original condenser location.
I suspect it's a modified aftermarket part placed in a original box (and sold for the higher price).
Photo 2.
An F-code Tach drive distributor. The part number FEJ-12127-D is correct for a S/C '57 T-Bird. The condenser is fastened underneath with a small screw on the right side. There is an oval Fomoco logo on the condenser.
File Type: jpg '57 Bird tach drive SC dist, condenser.jpg (34.7 KB, 21 views)
Old 06-11-2021, 05:42 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
"New Departure Bearings" has been in business since 1889 and is actually the oldest division of General Motors. "New Departure" is a quality bearing manufacturing conglomerate. DD
T5 W/TORQUE TUBE
Old 06-12-2021, 03:01 AM   #20
KULTULZ
KULTULZ's Avatar
Photo 1.
The part number printed on the box ends with a letter "A". The part number printed on the paper wrapper ends with a letter "B".
Photo 2.
That PHOTO shows the COND MTG I was seeking.
The plate looks correct (to me anyways). FORD may have had more than one vendor supplying the plate(s). It may be that the B - PLATE VENDOR used FORD ENGINEERING DRAWINGS to modify the original SGL PLATE stamping and machining.
The A - PLATE with VENDOR ID STAMPING is Shown below -
OK, I appreciate all the effort and now am comfortable if I ever come across this in the real world.
File Type: jpg Breaker Plate- 57-59 - B7A 12151-A _3.jpg (28.8 KB, 9 views)
