How to use vintage apco mossberg dial seems to go 24 inch lbs. If torquing head to 55 ft lbs.
If the wrench is marked in inch-pounds, it won’t go to 55 ft-lbs. Look for a wrench with a 3/8” socket.
Your wrench is for things like bearings and precision light work.
Thank you. I couldn't figure it out it was used in the aircraft engine maintenance previously.
Only thing I know of on a Model A off the top of my head that is spec'ed in that range is pinion preload at 20 in-lb.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#7 | |
![]() Quote:
www.whidbeymodelaclub.com |
Thank you all. Won't toss it as it was my Fathers he was in aircraft engine maintenance.
There are some semi-decent import beam-type torque wrenches out there in that range, but a good dial wrench in that range will set you back a mortgage payment. Please hold onto it, or sell it to me.
I've got all sorts of torque wrenches 1/4 3/8 1/2 being 3rd gen tinkerer. I just picked up this little adapter to toss in the tour tool box. https://www.harborfreight.com/12-in-...ter-58706.html
I don't think I've ever seen one with that range (24 inch lbs.) that wasn't basically a screwdriver.
Got a picture to share?
#13 |
Randy - CDI Torque (now owned by Snap-On, so you know what that does to the prices! But they're down in your neck of the woods - City of Industry) has several dial-type torque wrenches ranging from 0-15 in-lb on up. I have a couple of CDI ratcheting type that I got from Grainger years ago and they're quite nice. They have rebuild/calibration services as well. NIST traceable if you need it.
#14 |
Also get one of these: https://www.snydersantiqueauto.com/p...8661&cat=41753
#15 | |
![]() Quote:
This is what I was thinking about in my previous post. Apco Mossberg made several ratings of these, starting at about 6 inch-oz and up. (55 ft-lbs would be even more out of reach!!). ![]() ![]() - |
#16 | |
![]() Quote:
#17 |
Small screw sizes up to 3/16" are in that range. My old dial in/lbs torque wrench has a range of 0 to 600 in/lbs. The average one hand with a srew driver will get to 14 or 15 in/lbs.
#18 | |
![]() Quote:
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! Last edited by JayJay; 10-29-2024 at 10:43 AM. |
