Old 10-12-2024, 06:00 PM   #1
kimlinh
Default Wrist pin clearence
I want to put new pistons in a stock model A engine. The wrist pin diameters of the new pistons are smaller than the wrist pin diameters of the old pistons I will be replacing. ( It's a long story) The new pistons wrist pins will have a .002 inch Clearance between the rod bushing and the pistons wrist pin. This seems like a lot to me. My question is can I live with a .002" wrist pin clearance? Does anybody have any experience with loose wrist pins in a Model A?
kimlinh is offline   Reply With Quote
Old 10-12-2024, 06:05 PM   #2
Bigsnapper43
Default Re: Wrist pin clearence
I would have new bushing put in the rods and honed to size.
Bigsnapper43 is offline   Reply With Quote
Old 10-12-2024, 06:17 PM   #3
Flathead
Flathead's Avatar
Don't even think about running those pins at .002 inch. You will hear them all the way down the street.
Flathead is offline   Reply With Quote
Old 10-12-2024, 06:52 PM   #4
Dan McEachern
New bushing time. Find a shop that knows what they are doing. The bushings need to be expanded/burnished in the rod eye prior to machining them. Either they need to be bored using the big end bore as a reference or honed and then the connecting rod pins aligned to the big end. Clearance should be on the order of .0002/.0004". If the shop wants to just press the new bushings in and then hone them, find another shop.
Dan McEachern is offline   Reply With Quote
Old 10-13-2024, 06:57 AM   #5
nkaminar
nkaminar's Avatar
The pins should be a tight push fit in the rod ends and pistons. Some engines require the pistons to be heated to get the pins in.
While you have the rods at the shop, have them check the rods for alignment between big and small ends. Plus, have the weights checked and adjusted if necessary to make them all the same within reason.
Old 10-13-2024, 08:52 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
The Ford Service Bulletin of September-October 1932, Page 54, notes that the piston pin fit in the connecting rods should be 0.0002" to 0.0004" Clearance. The piston pin fit into the pistons at a temperature of 70F is a slight interference fit so that the pin floats in the piston when the engine is at operating temperature. The procedure for fitting piston pins is elaborately covered in the service bulletin.
However, I suggest that you buy pistons with the pins already fitted, and ream the connecting pin bushings to achieve a clearance of 0.0002" to 0.0004."
Bob Bidonde
Old 10-15-2024, 11:49 AM   #7
Jim Brierley
Dan is right! .0002/.0004 will give you a light palm push into the rod, with oil.
Old 10-15-2024, 09:05 PM   #8
Sunny the Model A
Sunny the Model A's Avatar
You got that right! I recently tinkered on a doodlebug that had that wrist pin noise, loud as shaking a can of pennies into a microphone! I hate that ******
noise
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
