A concept vehicle shown at Pebble Beach
this year completely burned inside of the trailer it was being towed from the event on a country road. The vehicle is assumed to be a gasoline powered front engine vehicle - the fire was intense. Towing appeared to take place during daylight hours. The trailer appears to have aluminum sidewalls and floor. Around the same time a Tesla Electric Semi Truck with no trailer attached burned up on I-80 Near Emigrant Pass. Looking at the images and reflecting on what I have seen over the years this doesn’t appear to be a fire caused by faulty electrical trailer wiring or faulty vehicle electrical wiring on a gas powered vehicle. This was intense heat. Perhaps the composite components of the vehicle fueled the fire. Your thoughts ? Still images taken from video at the scene & camera phone. Jim |
1979 Ford Probe with body by Ghia. Who knows how well they've maintained it? The owners are local to the Monterey area. I suspect a bad fuel line leaking gas onto a hot engine/exhaust. Someday we may know where the spark came from to ignite it. Factory prototype with hand beaten metal body. Ford designed it and had it built in Europe. The base car was a 2.3 liter turbo Mustang. It did have a large glass roof - I don't know if it was plastic or glass. The aluminum melting off the trailer looks pretty standard. Trailer probably had wood on the interior walls.
This is a subject that no one wants to talk about
Just having my friend lose his Pierce Arrow roadster and other cars to a fire makes me think more about it. Another Buddy lost his shop and garage to a Model A he was going to look at for another friend. Battery pos lead short caused source of ignition. I have been around racecars for many years and trailered all over the US. Never a problem, fuel drained and properly stored, batteries disconnected at least while in the trailer IMHO battery disconnect switches are worth their weight in gold. Just an opinion, J
As Carroll Smith wrote; All Failures are Human in Origin. |
don't forget spontaneous combustion oil soaked rags thrown in the floor, polish rags can cause a fire also.
That reminds me of the B-29 that was destroyed in Greenland in 1995:
https://planehistoria.com/kee-bird-b29/
#7 | |
![]() Quote:
Hello, I am a great believer in master electrical switches, put one in every collector car I owned,the MGB has a master switch and also a shut off for gas , electric pump. The Model A has one located on seat riser . I like to disconnect power when they are going to sit for awhile.
IMHO the very best disconnect is ……………. Just take the ground cable off ;-) easy peezy
agree with big hammer and never transport with a battery connected.
I also suggest that an enclosed trailer needs to be vented to the atmosphere to rid of gasoline fumes. Most vintage cars and trucks have fuel systems that are vented, so the trailer needs to be vented also.
Bob Bidonde |
I also believe in battery disconnect switches, and I shut the fuel off just before starting up the loading ramp on the trailer. This eliminates the fuel smell in the trailer. If the carb(s) are full they can spill a little fuel while driving, making a fire more likely.
#13 |
Fuel + oxygen + ignition heat + continued reaction = fire.
Bob Bidonde's suggestion is very good. It also applies to garages and barns etc. Remember that gasoline fumes, alcohol fumes, and propane are heavier than air so the venting needs to be low. Hydrogen and natural gas are lighter than air so vents need to be high. Likely the heat from the fire reflected back from the trailer walls and roof, making the fire intense quickly. Remember the old wisdom of with a fire in the engine compartment open the hood to let the heat escape. Scorching a firewall is better than a burnt car. Electric vehicle technology has batteries that seem to be better at not igniting than gasoline vehicles, but when they do the fire tends to accelerate fast and is difficult to extinguish. The sour old ex-volunteer firefighters 4th law of thermodynamics... "when you stuff more energy into a container when the container fails the bigger the boom" |
