Old 09-28-2019, 02:22 PM   #1
Joop
Joop's Avatar
Default Different Model A Venturi
Found this at a Swap Meet today.
Same as Zenith but with brass insert.
Does not look home made.
What is it for.
Thanks
Joop is offline   Reply With Quote
Old 09-28-2019, 02:53 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Different Model A Venturi
Looks like some sort of aftermarket venturi. Put it in a Zenith carburetor and see if it runs.
Mike Peters is offline   Reply With Quote
Old 09-28-2019, 03:33 PM   #3
Benson
since venturi is smaller maybe it is for a British engine ...
Although Henry would have used all pot metal unless there was a manufacturing problem which required brass for the smaller opening.
Brass was expensive
Old 09-28-2019, 04:17 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
If the inside diameter of the venturi is smaller it will restrict power .
Old 09-28-2019, 05:51 PM   #5
Joop
Joop's Avatar
Added some pictures
Old 09-29-2019, 06:00 PM   #6
Joop
Joop's Avatar
Any foreigh help on this
Old 09-29-2019, 06:03 PM   #7
daveymc29
daveymc29's Avatar
Si, No es Ford!
daveymc29 is offline   Reply With Quote
Old 09-29-2019, 10:17 PM   #8
Brad in Germany
Brad in Germany's Avatar
The carburetor for the AF engines did have a smaller orifice venturi (and smaller jet orifices as well).
Here is an original, April 1931, document from Zenith, France indicating the size of the AF single venturi. See the blue arrow indicating that the venturi of the carburetor for the AF engine is "18" compared to the venturi for an A and AA engine is "21.5" (look under the "Diff" column):
"Diff" = Diffuseur, the french word for venturi
So based on the measurements that you show of your mystery venturi, it seems like it is not a venturi for a Model AF engine.
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 09-30-2019, 07:16 AM   #9
Joop
Joop's Avatar
Thanks for posting that info Brad
Old 09-30-2019, 10:03 AM   #10
johnbuckley
johnbuckley's Avatar
Yes I concur with Brad the smaller engine was 18mm dia venturi ( approx 0.7 inch). Suspect that the venturi in the OP is someone's experimentation.
Old 09-30-2019, 02:56 PM   #11
SAJ
SAJ's Avatar
Originally Posted by daveymc29 View Post
Si, No es Ford!
Good one Davey!
SAJ is offline   Reply With Quote
Old 08-17-2024, 11:16 AM   #12
Wick
Wick's Avatar
Just found this one in a pile of carburetor parts.
Wick is offline   Reply With Quote
Old 08-18-2024, 11:04 AM   #13
Fullraceflathead
Fullraceflathead's Avatar
I wonder if it was an aftermarket accessory to improve fuel economy since it was around the time of the great depression???
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 08-18-2024, 01:37 PM   #14
Thodge
Thodge's Avatar
Might this be a part intended for use on an air compressor conversion running on two cylinders? Or maybe just a restrictor to improve economy on some sort of stationary power unit that would run constant rpm? From what I can tell, the Ford industrial engines used the standard Zenith but other engines in things like combines used unique carburetors. This might have been a bandaid to make the Zenith work better for those applications.
Thodge is offline   Reply With Quote
Old 08-18-2024, 01:49 PM   #15
ModelA29
ModelA29's Avatar
I can visualize the "double your mileage" ad in the back of a 1930s Popular Mechanics magazine.
ModelA29 is offline   Reply With Quote
Old 08-18-2024, 02:19 PM   #16
Thodge
Thodge's Avatar
I can picture that as well. On second thought though, it might actually increase fuel consumption over the stock venturi. Smaller opening would mean higher velocity at a given rpm, which would pull more fuel through the jets. Might help low end and throttle response though.
Old 08-18-2024, 08:34 PM   #17
Wick
Wick's Avatar
I'm going to take a good running carb and install it, I've got to see what it does.
Old 08-18-2024, 11:52 PM   #18
Johnbeere
Isn't that a model B venturi?
Johnbeere is offline   Reply With Quote
Old 08-19-2024, 09:54 AM   #19
Fullraceflathead
Could be 1 of them JC Whitney catalog miracle mileage gadgets they seem to have plenty of those in the 60s and 70s!!!
-Henry Ford
1941 Willy's Pickup
Old 08-20-2024, 08:40 PM   #20
Wick
Wick's Avatar
A friend here in Mathews just found a brass one sitting in his show case. Now I've seen two in less than a week.
