Old 07-17-2024, 08:50 PM   #1
mgambuzza
mgambuzza's Avatar
Default 2 Blade Fan Shortage
I've been trying to find a 2 blade fan for my 1930 Model A, but all of the normal sources are either backordered or out of stock. Does anyone know of a source that may have one on hand? I want to replace my water pump and fan at the same time (I have a steel 4 blade), and don't want to go into this twice.
mgambuzza is offline   Reply With Quote
Old 07-17-2024, 09:36 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: 2 Blade Fan Shortage
In the same boat, shows how thankful we should be for all of the suppliers WE DO currently have. I was told middle of summer months ago.
Harpkatt is offline   Reply With Quote
Old 07-17-2024, 10:16 PM   #3
CT Jack
CT Jack's Avatar
I recommend replacing the 4 pump mounting studs with A-8501-MBM pump mounting stud kit. Installing these studs will allow removing the complete pump without moving the radiator.
CT Jack is offline   Reply With Quote
Old 07-17-2024, 10:51 PM   #4
alexiskai
alexiskai's Avatar
Just to be clear, even if you replace the studs with bolts, when you pull the water pump you still have to rotate it up and forward to get the impeller to clear the head. You can't just lift it straight up.
With the 4-blade fan, you still have to remove (or at least substantially pivot) the radiator even with those bolts installed. If you put the 2-blade fan and the bolts in, that's when you can remove the pump without moving the radiator.
Old 07-17-2024, 10:52 PM   #5
Gary WA
Gary WA's Avatar
Got mine from BertsBert's Model A Center | Call: 303-293-FORD
www.whidbeymodelaclub.com
Old 07-18-2024, 07:27 AM   #6
Canton_Model_A's
Canton_Model_A's's Avatar
IIRC, I think I have a 4 blade fan. should I change this out to a 2 blade?
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 07-18-2024, 09:34 AM   #7
alexiskai
alexiskai's Avatar
They work fine, just slightly more inconvenient if you need to remove the water pump.
Old 07-18-2024, 10:09 AM   #8
Canton_Model_A's
I haven't even attempted that yet. still on the one when I got her in 2022. attached is a picture
Motor City A's Club
Old 07-18-2024, 10:38 AM   #9
Mike1291
Mike1291's Avatar
I've heard some people mention that some four blade fans were weaker because they have riveted blades. Not sure if this is correct or not.
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 07-18-2024, 11:09 AM   #10
Phil Brown
Phil Brown's Avatar
It's not because they have riveted together blades per say, it's the cracks that "might" develop from the holes for the rivets. It can happen but less seen than a rusty two blade fan. You need to keep an eye on ALL fans if you like your hood
Phil Brown is offline   Reply With Quote
Old 07-18-2024, 11:23 AM   #11
Benson
Besides the hood, other costs can include when un balanced fan blade starts shaking when the blade comes apart:
radiator $850
water pump $300
Surgery: thousands of $
if you happen to have your head in the area when the fan comes apart.
50 years ago I had a four blade come loose from the hub at 55 MPH. Lucky for me blades just made alot of noise and did not come apart when rivets came loose.
IN another case: The Coupe has a 4 inch hole in the hood where one of the fan blades went through the top of the hood. Never did find the blade.
Old 07-18-2024, 11:23 AM   #12
spdway1
spdway1's Avatar
Snyders (who has them made & distributes them to other vendors) said in a public release statement that they will have them in October.
spdway1 is offline   Reply With Quote
Old 07-18-2024, 11:27 AM   #13
Keith True
Keith True's Avatar
Almost all fans were riveted when they started stamping them.Age and rust get to them.One with tight rivets and no rust jacking should be fine.I've seen fans fail on newer stuff dozens of times.I had one propel itself through the radiator on a 5 year old S-10 with 48,000 miles on the truck.Fans are a big seller here at the junkyards.They all can,and do break.I lost an aluminum one on my A pickup in the late 90's.That motor was well clearanced and would really fly on flat ground.I was flying flat out when I had a big crash,then quiet,with a huge vibration.Half my fan was missing.There were huge voids,or air pockets in the casting near the hub.It was never in a straight plane,but it didn't vibrate so I used it.It came from JC Whitney maybe 25 years before I put it on.I have no idea if there was more than one maker back then or not.
Old 07-19-2024, 03:33 PM   #14
msmaron
msmaron's Avatar
they are scheduled to arrive back around October
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 07-21-2024, 10:10 AM   #15
Will N
Will N's Avatar
Originally Posted by Gary WA View Post
Out of stock, they're all out of stock: Brattons, Snyders, Berts, Ecklers...
Will N is offline   Reply With Quote
Old 07-21-2024, 10:28 AM   #16
alexiskai
alexiskai's Avatar
I haven’t checked with the second-tier vendors, but there’s a chance they have one. (S&J, Gaslight, Model A Medic, etc)
Old 07-21-2024, 11:06 AM   #17
JayJay
We had this same situation about a year ago. I got lucky and ordered two when they were available.
BTW, beware that the noses of some water pump housings may rub on the inside of the cast 2-blade fan. So test fit your fan to the water pump before tightening down the nut. You may have to grind off a bit of the nose of the water pump casting to make an interference-free fit. I had to do this with two water pump housings I had.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 07-21-2024, 12:29 PM   #18
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Makes me glad I am running one of the non-original multi blade plastic fans!!
fried okra is offline   Reply With Quote
Old 07-21-2024, 01:39 PM   #19
Gene F
Gene F's Avatar
Me too, and I checked it to be snug after it was on a while, and now I just forget about it. I drive/tour with my car, and am not a purist.
Old 07-21-2024, 08:49 PM   #20
Synchro909
Synchro909's Avatar
Me three. I like the cast aluminium fans for their original look and safety but for trouble free longevity, I don't think the plastic ones can be beaten.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
