Old 07-20-2024, 12:37 PM   #1
blownford
Default Seal on top of grille
'36 5 window, there's a flat rubber seal (hard as a brick) on the top of my grille. I don't see it in the green book or any of the parts houses. I'm guessing it's not original but thought I'd ask.
blownford is offline   Reply With Quote
Old 07-20-2024, 01:09 PM   #2
Kens 36
Kens 36's Avatar
Default Re: Seal on top of grille
That is a correct part. I believe it is called grille shell lacing or radiator shell lacing. Available from various vendors, including Dennis Carpenter and C&G Automotive. Look for Part # 68-8222.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 07-20-2024, 01:18 PM   #3
Model51
Model51's Avatar
If you don't already have a copy, you may want to consider purchasing the 1935-1936 Fords book from the Early Ford V8 Club. It contains lots of great detailed information about these cars.
Their book store is closed until August because it's being moved. Here's a link to get you started: https://shop.efv8.org/
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 07-20-2024, 02:51 PM   #4
blownford
Thanks! I ordered one from Third Gen.
I have the wonderful '35 - '36 book, use it all the time. I didn't see it in there though, probably just overlooked it. I'm getting blind
Old 07-20-2024, 03:35 PM   #5
mercman from oz
mercman from oz's Avatar
Grille Shell lacing on 1936 Ford Grille gone hard, needs replacing - blownford
