Old 06-23-2024, 07:38 PM   #1
DFS
Default Access to '37 fuel sender
I need to troubleshoot the fuel gauge for my '37 4-door sedan. There are two covers about two inches in diameter on the floor of the trunk, would one of these access the tank sender? Thank you.
DFS is offline   Reply With Quote
Old 06-23-2024, 08:09 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Access to '37 fuel sender
Old 06-23-2024, 08:23 PM   #3
petehoovie
petehoovie's Avatar
Neither one...From what I recall, there is a tongue shaped flap/access-door that covers the sending unit...
I think I see it, partially covered by carpet, on the bottom right side of your "L" photo...
See > https://www.jalopyjournal.com/forum/...2-jpg.2767738/
and > https://cwmoss.com/products/gas-tank...r-1937-41-ford
Old 06-23-2024, 08:26 PM   #4
Kube
Kube's Avatar
Those are NOT the access holes.
In the photo depicting the left side, it appears there is a trap "door" just below and to the right. That "door" is held to the floor with one screw. If that 'door" has never been removed, there will be tar around the edges. That tar can be chipped off rather easily.
I have attached two photos that while not the best quality, should certainly help you locate what you seek easily.
Old 06-23-2024, 11:38 PM   #5
deuce lover
deuce lover's Avatar
You can barely see the edge of the lid in the bottom of your pic marked "L".
Old 06-24-2024, 06:30 AM   #6
DFS
Thanks everyone. Access is embarrassingly obvious now!
Old 06-24-2024, 07:04 AM   #7
jimTN
I have never seen a 37 with that round three screw cover, what is it for?
Old 06-24-2024, 07:46 AM   #8
Kube
Kube's Avatar
Those were originally tack welded in place.
Old 06-24-2024, 10:41 PM   #9
Dameon Hubbard
Definitely a trap door held in place by a screw as KUBE explained.
Dameon Hubbard is offline   Reply With Quote
