Old 04-18-2024, 04:47 PM   #1
cdnwillyg
Default Newbie with '29 RPU
Hey forum new here and the new owner of a '29 RPU in need of some love.
I have this issue on the rear quarters where it meets the cab floor and don't know what I need to do? Its the same on both sides. It looks original but after 95 years thats only a guess.
I should mention there are no body wood blocks in yet so body is sitting directly on the frame.
cdnwillyg is offline   Reply With Quote
Old 04-18-2024, 05:30 PM   #2
Chuck Dempsey
Chuck Dempsey's Avatar
Default Re: Newbie with '29 RPU
Can't help with your issue, but welcome to the 'Barn! Looks really nice.
Chuck Dempsey is offline   Reply With Quote
Old 04-18-2024, 06:05 PM   #3
Gary WA
Gary WA's Avatar
Great project!!! Welcome to Site! Get R Done!!
www.whidbeymodelaclub.com
Old 04-18-2024, 06:54 PM   #4
Marshall V. Daut
Not to nitpick your nice truck, but you'll need the correct hood. The one that is presently on your Model A is from a '28-29 Fordor Sedan or a 1929 Town Sedan/Town Car/Cabriolet. Fortunately, the hood you need is much more commonly found than the hood for those cars. You should be able to trade or sell yours at an advantage. It looks pretty straight across the top, a rarity among hoods that are usually dented.
Marshall
Marshall V. Daut is online now   Reply With Quote
Old 04-18-2024, 06:56 PM   #5
jg61hawk
First off...welcome to the forum and the Model A world. I'll be in trouble for this with some...but not with all. ...it all depends on what you are trying to accomplish as an end game. I can't see clearly your entire situation, but if everything is solid in terms of safety...floors etc...then some good old modern construction cement, such as Hard as Nails, or some equivalent should solve your problems...it solved mine. I had some rot in a car I did not want to restore to factory....squirted that stuff, braced it tight for 48 hours and painted in black...looks like welding. You do what you want...welcome aboard.
jg61hawk is offline   Reply With Quote
Old 04-18-2024, 10:05 PM   #6
cdnwillyg
I have the original hood too, I was told that the hood with the bead roll is from a closed cab pickup??
Old 04-18-2024, 10:09 PM   #7
cdnwillyg
I will be replacing the little rot in the cowl with new steel and the truck has been sandblasted so there's no need to try and save any of the paint....it will be shiny.
Old 04-18-2024, 10:21 PM   #8
cdnwillyg
Thanks for the Welcome!!!
So another question about the two sets of 3 holes behind the seat, 1 set passenger,1 set drivers???
Old 04-18-2024, 11:44 PM   #9
Marshall V. Daut
"I was told that the hood with the bead roll is from a closed cab pickup??"
You were misinformed. The pictured hood on the truck belongs only to the body styles I listed in Post #4. A '28-29 Closed Cab Pickup would use the same hood as one of the Coupe varieties (Standard, Special, Sport, Business), Roadster, Phaeton and Tudor Sedan. All these had exposed gas tanks, whereas the ones on my list had concealed gas tanks and were built around a wood structure. The concealed gas tank bodies used the hood with a rolled bead shown on your Model A.
Marshall
Old 04-19-2024, 12:41 PM   #10
rotorwrench
rotorwrench's Avatar
I believe that the back of the cab wall had either had vertical wood supports or horizontal. I think the seat back cushion attached to them. See Link.
The cab corners look almost complete as far as metal loss due to corrosion. Most are rotted completely out. I would remove any corrosion rot there and fabricate butt weld patches. Only remove what is not solid and replace with same gauge of metal. Cab corners are available but yours are definitely salvageable and they already fit.
https://fordwood.com/images/rpu28new.jpg
Old 04-19-2024, 06:54 PM   #11
cdnwillyg
There is no rot down on the floor, its just not pot riveted or welded there, almost like its there for drain age??Both sides are the same. I'm thinking this cab had the top and side wide shades at one time and that's what the holes around the top where for the snaps....but just my guess by the drivers one snap left.
Got a little stripping done today.
Old 04-19-2024, 07:06 PM   #12
Keith True
Keith True's Avatar
The tops were not held on with snaps on those trucks,they were nailed on.They were not removable or foldable.There is supposed to be a piece of wood on top of the back panel,the roof nails onto that.Look at some of the pictures online from the suppliers,you will be able to see what it looks like.On both my 28 and 30 open cabs I used fasteners,I wanted to be able to take the roof off if I needed to.I still have the 30,and in 20 years I've never had reason to remove it yet.
Old 04-21-2024, 10:37 AM   #13
rotorwrench
Folks call them roadster pickups but the were really just an open cab pickup. Some folks modify the bottom rear of the top with snap fasteners so that is can be removed. Others make custom folding set ups but there isn't much behind to support a folding top.
Old 04-21-2024, 11:10 AM   #14
Marshall V. Daut
For a couple years, Lebaron Bonney made complete folding top irons for the '28-29 Open Cab Pickup Truck. They seemed relatively expensive at the time, but look darned cheap now! You might try advertising for a set of these irons. Someone may have a set not needed and will be willing to part with them.
Marshall
Old 04-22-2024, 08:53 AM   #15
cdnwillyg
Thanks for the info, the top if it gets one will be down the road after everything else is done. But I will source to see what I can find now.
If the power train and running gear are good then keeping it original maybe the way I'll go as it will be the cheapest route. If it is in need of lots of repair then
I'm looking at changing the wheels to the 16" ones of the 30's for two reasons, I need new rubber for the 21" rims and if I go to a Flathead V8 and lower the suspension then I would be able to keep the new 16" rims and tires on it.
Any thoughts to my thinking??? Like I said this is all new to me and would like input,
Old 04-24-2024, 11:34 AM   #16
rotorwrench
Many AV8s have been put together but it is a lot of work. The Bishop/Tardel book describes the way a lot of folks did it back in the day. The HAMB has a lot more information about such mods. It's a challenge to fit a V8 in the confines of a 1928/29 engine compartment. The frame has to have at least some reinforcement for the extra weight and torque.
Old 05-02-2024, 06:22 AM   #17
50Trucking
50Trucking's Avatar
I have been a member since 2020 and can not figure out how to post. Can some one help?
50Trucking is offline   Reply With Quote
Old 05-02-2024, 07:21 AM   #18
Keith True
Keith True's Avatar
Is anyone making the top frames right now for the open pickups? Original type,non-folding,and NOT the universal ones.
Old 05-02-2024, 08:00 AM   #19
Chuck Dempsey
1) Go to 'Advanced'
2)Click the 'paperclip' on tool bar
3)Click first 'Choose File'. It will bring up your File explorer... Pick you picture to upload...then click 'Open' at bottom right of screen.
4) Click 'Upload' after it has moved your pic choice into 'Choose File' box.
5) If all worked, you should see you pic listed in the 'Current Attachments' box.
6) Hit 'Submit Reply'.
Old 05-02-2024, 08:02 AM   #20
Chuck Dempsey
Screen shots -
