Old 04-10-2024, 12:44 PM   #1
cjshaker
cjshaker's Avatar
Default Removing caps on '37 hubcaps?
I'm looking for pointers on how to remove the stainless caps on '37 hubcaps so that they can be restored, and the bases painted. I don't want to damage them, and they look to be easily damaged if not done right.
Old 04-10-2024, 01:03 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Removing caps on '37 hubcaps?
Drill a small hole on the back of the hubcap through the steel. Be careful as not to go through the stainless cap on the outside. Use compressed air to blow air into the small hole. The cap should come off.
Old 04-10-2024, 01:16 PM   #3
Zeke3
Zeke3's Avatar
You will also find more tips on restoring these hubcaps by searching this forum using the “Advanced Search” and search for “hubcap” and the author is “Nelsb01”.
For example this discussion: https://www.fordbarn.com/forum/showt...hlight=Hubcaps
Zeke3 is offline   Reply With Quote
Old 04-10-2024, 01:32 PM   #4
Kube
Kube's Avatar
Seth is spot on. I place the cap over a thick towel to "catch" the stainless part.
Old 04-10-2024, 04:38 PM   #5
jimTN
when you paint go easy on the area under where the little cap goes or it will not go back on easily
Old 04-10-2024, 04:44 PM   #6
cjshaker
cjshaker's Avatar
Thanks for the suggestion of compressed air. I would not have thought of that one. I think I'm more nervous now about getting them back on without damaging them. Making a mold would be a lot of work, so I'll have to think that over a bit.
Thanks again,
Doug
Old 04-10-2024, 07:48 PM   #7
hotcoupe
hotcoupe's Avatar
I concur with what jimTN said , don't apply a lot of paint to the portion of the hubcap where the stainless steel cap goes on. I have used Variprime, made by Du Pont. Place the carbon steel in the freezer overnight and heat the stainless in the oven @ 200° for 20 minutes, it will slip right on.
Hope this helps,
Tom
hotcoupe is offline   Reply With Quote
Old 04-10-2024, 08:01 PM   #8
Kube
Kube's Avatar
I actually carefully tape that area after the first coat of paint has been applied.
Place the stainless cap on a suitably sized plastic bucket with a thin towel draped over the edge to install the center. It goes on fairly easy.
Old 04-10-2024, 11:16 PM   #9
petehoovie
petehoovie's Avatar
Hope this helps,
Tom
Old 04-11-2024, 04:03 PM   #10
cjshaker
cjshaker's Avatar
Hope this helps,
Tom
Thanks for that suggestion. Heating and cooling parts to mate them is a long practiced good idea, so long as I don't over cook it. That would ruin the flavor.
Old 04-11-2024, 04:22 PM   #11
Seth Swoboda
Just use it as a pre-heat for a pizza you can bake after for your reward.
Old 04-11-2024, 06:30 PM   #12
Kube
Kube's Avatar
It can be done
The "after restoration" photo is overexposed. Rest assured the blue V8 is much darker in real life.
