Old 03-26-2024, 03:45 PM   #1
jeepguy1948
Default .100” Over Piston Rings
Hastings no longer makes the .100 over piston rings for the 8BA so I could use some help sourcing a set. I know that it “might be possible” to use .125 rings and file the gaps but I think that is out of my skill set, even if it was possible.
jeepguy1948 is offline   Reply With Quote
Old 03-27-2024, 09:50 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: .100” Over Piston Rings
I could never figger out why a person would bore ther block out to .100", when .125" offers so many options. Think first!!!!!
Gramps
Old 03-27-2024, 11:24 AM   #3
jeepguy1948
Block was bored .100 40 years before I got my hands on it and there is no way in h**l I’m going to bore it out and buy new pistons because of piston rings
Old 03-27-2024, 12:43 PM   #4
Bob C
Egge shows .100 rings. https://egge.com/product/piston-ring-set-79/
Old 03-27-2024, 01:01 PM   #5
kurt v
check with Mac Vanpelt
kurt v is offline   Reply With Quote
Old 03-27-2024, 02:33 PM   #6
Ronnieroadster
Ronnieroadster's Avatar
.100 rings are available do some research their not impossible to find.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 03-27-2024, 06:20 PM   #7
jeepguy1948
Kurt, I checked with Mac yesterday, that’s when I found out that Hastings had discontinued them, he was not able to suggest an alternative.
Old 03-27-2024, 06:22 PM   #8
jeepguy1948
Ronnie, I am doing research, this thread is a part of it. I don’t want to be banging my head against a brick wall if somebody more experienced than me has the answer. I learn from mistakes, I prefer it to be someone else’s mistakes however.
Old 03-27-2024, 06:30 PM   #9
jeepguy1948
Thank you Bob, they’re (EGGE) is closed now but I will call them in the AM.
Old 03-28-2024, 01:59 PM   #10
Ronnieroadster
Egge definitely offers .100 over replacement pistons if anyone can get rings its certainly Egge to go along with the pistons so they should be able to help you out.
Ronnieroadster
Old 03-28-2024, 03:56 PM   #11
Ol' Ron
Ol' Ron's Avatar
I just thought you'd have a better selection of better rings. The old design didn't last long, maybe 30/75 K miles. Just trying to keep up with Kubota. My latest engine has 70 year ol pistons and rings. tho
Gramps
Old 04-01-2024, 08:31 PM   #12
Cameron Koehn
Cameron Koehn's Avatar
I just built an engine .100 over. I got Grant rings from Red's Headers. Those are cast iron all the way. I broke one and Grant didn't want to help me. I called up Egge and they were very helpful and got me what I needed. If I could do it over, I would use Egge for the entire ring set.
Flathead Flatfender
Cameron Koehn is offline   Reply With Quote
