01-16-2024, 09:47 AM | #1 |
36 radiator cap question
My 36 has an original type brass radiator, which currently has a chrome or nickel plated cap with a paper type gasket (which leaks steam readily), and an overflow tube from the upper front center of the radiator which appears to be open to atmosphere. Did the 36 originally come with a pressurized type cap? If this setup is all original I don't see how it could build pressure with the overflow tube that it has. So Ford thought it OK to run a system that boiled at 212 degrees? Do people change this setup to run low pressure caps?
Thanks! Pat |
01-16-2024, 09:53 AM | #2 |
Re: 36 radiator cap question
Ken
https://www.nirgv8.org |
