Old 01-05-2024, 01:48 PM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Carburetor Fuel Level Gauge - Suggestions on making one please?
Our fuel level gauge has gone missing, and it appears they are out of stock, -so I guess I need to make one. Therefore I need a little inspiration.
If I were to use a regular carburetor drain, it appears I have around 3/16" of an area inside of the plug that could be drilled, ...then a small length of 3/16" O/D steel Brake line installed and JB Weld added to hold it in. It appears McMaster has 3/16" clear tubing. Before I go thru the steps of this, does anyone know of an easier way to make one of these??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-05-2024, 02:06 PM   #2
LeonardS
Default Re: Carburetor Fuel Level Gauge - Suggestions on making one please?
$16 at Renners Corner.
LeonardS is offline   Reply With Quote
Old 01-05-2024, 02:25 PM   #3
Rob Doe
I have a gauge from Dave's corner. It works well. As I recall, it is locked at the drain point of the carb, and requires the lower half of the carb to be removed from the car to remove it from the carb. Shortening the U shaped connection seen in the above photo might eliminate the requirement.
I have seen a diagram of a different construction which allows removal from the carb when the setup is on the car. I'll try to remember where I saw this, but Brent, I bet with your knowledge you can envision the connection of which I speak. The parts at the base were not glued but screwed together, maybe a ferule fitting...
Hope this helps.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 01-05-2024, 02:29 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Renner's Corner has fuel level gauges for various carburetors. This one for a Marvel. I like the Renner's one because it holds it shape, even with the engine running.
Old 01-05-2024, 02:31 PM   #5
Gary WA
Gary WA's Avatar
Brent here's the one I have your idea sounds good, the stiff wire keeps the tubing to shape-simple.
www.whidbeymodelaclub.com
Old 01-05-2024, 02:41 PM   #6
P.S.
Here is a video showing the Renner's Corner kit in use- https://www.youtube.com/watch?v=WfSB-9fPGTY
2024-2025 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 01-05-2024, 09:25 PM   #7
katy
katy's Avatar
Why not solder or braze the steel line? I've seen JB weld eaten by gasoline.
Old 01-05-2024, 11:52 PM   #8
oldspert
oldspert's Avatar
Flux coated silver solder works wonders in this application.
oldspert is offline   Reply With Quote
