Old 12-02-2023, 10:42 AM   #1
Brian SATX
Brian SATX's Avatar
Default Dipsticks
I know I hve seen a graphic that shows the differences in dip sticks used for the Model A but cannot find it. I checked Judging Standards to no avail. Can anyone help?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 12-02-2023, 12:44 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Dipsticks
this it
www.whidbeymodelaclub.com
Old 12-02-2023, 03:46 PM   #3
JayJay
I looked at the thread title, thought we might get a discussion about clueless drivers...
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 12-02-2023, 05:48 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Old 12-02-2023, 10:43 PM   #5
Brian SATX
Brian SATX's Avatar
Thanks Gary. Where did you find this? I have since looked in the Ford Parts book and also only find one for the Model A.
Brian SATX
Old 12-02-2023, 10:46 PM   #6
Gary WA
Gary WA's Avatar
Someone else supplied and I saved it.
Old 12-02-2023, 11:03 PM   #7
JayJay
Deleted.
JayJay
Old 12-03-2023, 10:05 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
The picture in Post #2 is from the Ford Service Bulletin of August 1932,Page 50, Figure 77.
Bob Bidonde
Old 12-03-2023, 11:18 AM   #9
BillCNC
BillCNC's Avatar
I had the same question when I first got my Model A so I ended the puzzle by making my own mark.
I removed the oil pan and the inner baffle to clean everything out along with removing the valve cover and cleaned it out as well. I then added 5 quarts and ran the motor for a few minutes making sure there were no leaks. I then shut it off and after waiting for a 1/2 hour or so for the oil to drain back into the pan, I pulled the dipstick and used a small jeweler's file to cut a small oil level line into the dipstick.
No more guess work and now I know exactly how much oil I have in the motor at anytime.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 12-04-2023, 10:52 AM   #10
Bob Bidonde
BillCNC! Where is the mark you made relative to the "F" & "L"?
Bob Bidonde
Old 12-04-2023, 01:46 PM   #11
BillCNC
BillCNC's Avatar
About 3/16" above the "F".
Regards
Bill
Old 12-04-2023, 07:58 PM   #12
Gene F
Gene F's Avatar
Speaking of oil...how often do you guys change it?
Old 12-06-2023, 05:20 PM   #13
JimK1930A
JimK1930A's Avatar
I change my oil every 500 miles. I do not have an oil filter.
JimK1930A is offline   Reply With Quote
Old 12-06-2023, 10:05 PM   #14
BillCNC
BillCNC's Avatar
I change mine every 500 miles which turns out to be once a month. I buy the 3 gallon box Rotella T4 15w-40 from Walmart for the same price of two 1 gallon jugs.
Daily Driver
Regards
Bill
Old 12-10-2023, 03:51 PM   #15
Sunny the Model A
Sunny the Model A's Avatar
I put a partial flow filter on my daily driver truck and change my oil when it gets dark, if it doesn't get dark every 5000 miles. I use the cheapest 10w30 I can find, usually walmart oil. stock A's don't need high dollar oil, considering that they don't turn very fast, nor do they have high pressure valve springs.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 12-10-2023, 08:02 PM   #16
David in San Antonio
David in San Antonio's Avatar
Currently The Wretched Roadster leaks oil so successfully that the oil never gets dark.
Late ‘30 Deluxe "Wretched Roadster"
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 12-10-2023, 09:05 PM   #17
CT Jack
CT Jack's Avatar
Something to consider the next time you have your pan off and that is to drill a couple of small holes in each depression in the baffle. This will allow any oil remaining in the baffle to drain back to the crankcase.
CT Jack is offline   Reply With Quote
Old 12-10-2023, 09:18 PM   #18
Y-Blockhead
I'm not sure that is such a good idea. Not much oil available for the rod bearings on start-up. Henry made the dipper tray like he did for a reason.
Old 12-11-2023, 10:16 AM   #19
CT Jack
CT Jack's Avatar
Y-Blockhead you are probably correct. I forgot about the dippers on the rod ends. This is not a pressurized oil lubrication system. My bad idea.
Old 12-11-2023, 12:34 PM   #20
Bob Bidonde
BillCNC, about 3/16" above the "F" on the dip stick is too much oil. Typically Model "A's" run about midway between the "L" and the "F".
Bob Bidonde
