Seems the foam rubber, rectangular floorboard seals for a 36 are out of stock everywhere I have checked. Maybe no longer reproduced? Does anyone have any or know of a source, or an alternate solution?
Thanks! Pat |
I cut my own floor boards by using what was left of the old junk, then got some felt and stapled it to the edges, worked good
I used square sponge rubber sealer from a hardware store sold in a roll. I think it was intended to seal up leaks in old windows and doors. It came with glue on one side and a peal away strip of paper. I cut to length and glued to the outside of the floor boards. It came out decently, but probably not as nice as if I had the proper reproduction seals.
My friend Bob has these new in the package, that he mistakenly purchased for his '35.
If you are interested, PM me and I will give you his contact information. We are in Canada. Kirk
1953 Ford F100 1950 Ford F47 (F1) 1940 Ford Pickup |
There's a difference between 35 and 36?
Looks to be 36 only from the vendors I've looked at. Seems there would also be a difference if a car had steel instead of plywood. So if Kirk's friend, Bob, has the '36 seals, maybe it's my lucky day.
