Old 10-08-2023, 05:52 PM   #1
BobR35
BobR35's Avatar
Default 12V access alternatives
Since I purchased my '35, 3 years ago and realized that I needed some 12v accessories, headlight to see the road at night, 3rd tail light in the rear window, and a USB port, I found a converter that worked and then I was hard pressed to find a way to mount it. FYI, I was able to make a fuse panel and mount it under the dash. It actually works pretty good, doesn't show and doesn't interfere with any original equipment. I was just wondering if there was any other ideas that was out there and what you did if you did?
BobR35 is offline   Reply With Quote
Old 10-08-2023, 07:49 PM   #2
Brian
Brian's Avatar
Default Re: 12V access alternatives
dash cam?
Old 10-08-2023, 08:02 PM   #3
BobR35
BobR35's Avatar
Originally Posted by Brian View Post
dash cam?
probably could use one facing the rear the way people run up on me in traffic. On the highway I put a yellow strobe light on the trunk to warn drivers of my slow speed.
Old 10-09-2023, 10:58 AM   #4
JayChicago
JayChicago's Avatar
At night I attach this flashing LED. Very bright red or white LED, steady on or flashing. Hook and magnet holds it on the bumper. And the price is right.
https://www.harborfreight.com/56-lum...ght-63722.html
Old 10-09-2023, 12:10 PM   #5
petehoovie
petehoovie's Avatar
Old 10-09-2023, 03:50 PM   #6
slowforty
slowforty's Avatar
You used to be able to get those Free with a Purchase. Once in a while they will have a free coupon.
slowforty is offline   Reply With Quote
Old 10-09-2023, 06:12 PM   #7
BobR35
BobR35's Avatar
We share similar ideas on that, I have a bicycle ref flasher on the spare tire that I use. Also a yellow strobe light with magnet that I put on the trunk top if I'm driving on the highway. I'm at 45-50 with approaching traffic somewhere just below 90 mph, crazy on I-95. I try avoid that road of I can!
