Old 09-28-2023, 12:08 PM   #1
hotcoupe
hotcoupe's Avatar
Default Flathead Ford valve train questions
Hello, I took a "59" block to the machine shop recently along with some new internal components, among the supplied parts were a set of N.O.S. Ford hollow lifters. I'm a little gun shy of the current Johnson style lifters, improper material or heat treatment, causing the lifters to fail. My question is, do I need to use a custom length valve, I speced a Manley 1.6" Pro- flow valve. Does anyone have any practical experience in this situation.
Thanx,
Tom
hotcoupe is offline   Reply With Quote
Old 09-28-2023, 03:07 PM   #2
Pete
Default Re: Flathead Ford valve train questions
Thanx,
Tom
You are right in not using adjustable lifters.
The lifters you should use are the OEM STEEL ones with ONLY two 5/32 holes in the side. NOT the ones with the slots.
If you are using an original stock cam the Manley valves should be long enough to grind to proper length.
If you need to add some length, you can put Eutectic 16FC rod on with a torch or you can TIG weld 347 stainless on the tips.
Old 09-28-2023, 07:12 PM   #3
hotcoupe
hotcoupe's Avatar
Thanx Pete, I was hoping you would chime in.
Tom
Old 10-03-2023, 09:02 AM   #4
hotcoupe
hotcoupe's Avatar
Pete, just to be clear, the hollow lifters (pictured below) are not appropriate for a mild street engine application. I always thought the lighter weight would be a benefit. I'm always interested in your comments.
Tom
Old 10-03-2023, 09:09 AM   #5
tippa77
tippa77's Avatar
Hi
so the ones with holes are better than slots ?
tippa77 is offline   Reply With Quote
Old 10-03-2023, 09:35 AM   #6
barnfind08
The ones with the slots ran from 1932 to 1940 when Ford changed. As far as I can tell that was awful lot of cars and racers that never had any trouble. Just saying.
barnfind08 is offline   Reply With Quote
Old 10-03-2023, 09:43 AM   #7
old splicer
old splicer's Avatar
Who would be the best source for steel lifters
old splicer is offline   Reply With Quote
Old 10-03-2023, 09:50 AM   #8
Ol' Ron
Ol' Ron's Avatar
For street use, I like to use the valve rotators. I've used these on the Max #1 cam and so far (15 years) they work fine. It's just a stock 258, not sure how many miles ont, Have to call him and ask.
Gramps
Old 10-03-2023, 10:30 AM   #9
Pete
Tom
The ones with slots are cast iron and prone to breaking with a performance cam.
It is not a metal compatibility problem.
The steel ones, identified by two 5/32 holes in the side, first appeared in 1932
and are lighter than the cast iron ones.
Old 10-03-2023, 10:44 AM   #10
petehoovie
petehoovie's Avatar
