I recently bought a radiator fan from Speedway and it didn't help my overheating problem one degree so sent it back for a refund. I mounted it in front of the radiator to blow through it. Although I detected a slight vacuum in front of the fan when it was running. I could hardly feel any air coming through the radiator.
My radiator is a brand new aftermarket radiator that I've already concluded is not as good as my old original that was totaled when I hit a deer a year ago. I'm just trying to get it to work better without having to replace it with a used original. What is the best, most powerful 6 volt fan to use? Thanks in advance for your recommendations
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
From what I can see from their web site Brassworks doesn't list 6 volt fans. But I'd give Lee at Brassworks a call and see if he has any suggestions. If he has a recommendation I'd go with it. But that's JMO
The Brassworks; handcrafted radiators made in the USA 805-239-2501 805.239.2501
51504BAT, thanks for the info. I'll call Brassworks tomorrow.
I've also thought of installing a fan shroud to improve the cooling climbing at low speeds but have not found a source for one. Anyone with a source for a fan shroud for 47 Sedan?
My recommendation is to use an engine driven fan and a shroud to improve air flow through the radiator. Moving air requires horsepower and having only six volts and maybe 30 amps isn’t going to get the job done.
Here's a little calculation for you about a 6 volt fan. Conventional wisdom says that it takes from 2 to 5 HP to turn an engine driven fan. 1 HP equals 745 watts, so the best case, you need 1490 watts to turn an electric fan for the same effect. 1490 watts/6 volts=248.3 amps. I know these are theoretical figures, but in the real world Flex-A-Lite (who claim to make the most efficient automotive fans) state their fans require between 17.5 and 29 amps to function on 12 volts. That translates to 35 to 58 amps for a 6 volt version. Good luck getting that out of your generator (or even your alternator).
No wonder Brassworks doesn't list a 6 volt fan. |
https://www.ebay.com/itm/19600418454...%7CMake%3AFord Another thought: Johnson Hot Rod Shop has acquired the tooling from Walker Radiator Company. I wonder if it would be worth while to bite the bullet and buy a radiator from them once they start production. Perhaps, give them a call. https://theshopmag.com/news/johnson-...adiator-works/ Last edited by 19Fordy; 10-02-2023 at 11:36 AM. |
Good day Professor. You mentioned that there was a slight vacuum in front of the radiator.
Is the mech fan around an inch close to the radiator? When I had my 46, I could put a small light weight towel on the Radiator while the car was running and the vacuum with hold it on there so that way I knew I had some decent airflow going. Perhaps a crude way of testing but at least I knew. Is it overheating while in motion or at stops? Has it always given you overheating issues? If not, what’s the last mod or repair did you do to the car? In my own personal experience sometimes the last thing I did created new issues. I do hope you find a resolution so that you can continue to enjoy your road trips.
If it aint broke, don't fix it! |
[QUOTE=19Fordy;2259687] Is this 4 row what you are currently using?
https://www.ebay.com/itm/19600418454...%7CMake%3AFord I don't know what radiator the body shop put in. I just know that it had extra rows to be more efficient . . NOT.
#9 | |
![]() Quote:
The overheating was at the top of the climb up Kyhv Peak road to the overlook after climbing in 2nd gear for 15 -20 minutes. With my old original stock radiator I could make that climb in 90°+ weather without boiling over. With the new "improved" radiator I boiled over when I got to the top in only 87° ambient temperature. My water temperature gauge was 10° higher than with the stock radiator. The weather is cooled here now and we will soon be leaving for another mission for the church for a year or two so I probably won't undertake replacement of the radiator with a used stock one until after that. Thanks for your interest and concern.
