Old 07-22-2023, 05:00 PM   #1
TerryS
TerryS's Avatar
Default New carb saga goes on. 34 coupe v8
So I changed my old worn out 94 carb to a new stromberg 97. Now I don't have enough travel in the gas pedal for wide open throttle.
The 94 ball attachment was from the botton, under the throttle plate. The 97 pulls from the top, There must be less travel? Are there different length linkage rods?
Thanks Terry S
TerryS is offline   Reply With Quote
Old 07-23-2023, 05:10 AM   #2
TerryS
TerryS's Avatar
Default Re: New carb saga goes on. 34 coupe v8
So does anyone know if someone makes different length accelerator rods? The original was 9.5 in.
I have a made up 8 inch one but was way to short. I think I need something like 8.75 or 9 inches?
Thanks Terry S
Old 07-23-2023, 05:48 AM   #3
Mac VP
Mac VP's Avatar
We sell a longer adjustable rod that is an original Ford part for a truck application. It adjusts from 11.875” to 12.875”. You can also cut it down and rethread it as needed to customize the length.
http://www.vanpeltsales.com/FH_web/F...hrottlerod.jpg
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 07-23-2023, 07:16 AM   #4
coup34
Dad put a short on my car back in the 50s, but I did figure it out.
coup34 is offline   Reply With Quote
Old 07-23-2023, 11:48 AM   #5
TerryS
TerryS's Avatar
Just dug up old manifold in the collection.
I was able to clean up an resize an arm from there.
It works....
Thanks Terry S
