Old 07-12-2023, 10:49 AM   #1
kurt v
Default piston to head clearance
Have .050 from top of piston to head with gasket , head being held down by my son while i turn motor over, will this be good when head is torqued down?
using best gasket set.
thanks
kurt
kurt v is offline   Reply With Quote
Old 07-12-2023, 05:09 PM   #2
cadillac512
cadillac512's Avatar
Default Re: piston to head clearance
Kurt, it most likely will be, but here's my method: Put the head on with no gasket and turn the engine a full revolution. If nothing hits it'll be fine with the Best gasket. If it just barely bumps the head and doesn't raise it more than .010" it'll also be just fine. I've found the gasket to compress approx .005" when torqued, and I've run as close as .033" piston/head clearance without issue.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 07-13-2023, 12:42 PM   #3
kurt v
Thanks Terry, i thought that .o40 to .045 would be good.
thanks
kurt
Old 07-13-2023, 04:37 PM   #4
alanwoodieman
.o55 for aluminum heads, checked with a ball of aluminum foil
