Positive ground car, how is the coil wired?
Bob Giles, thanks |
Don't know why the link isn't working...let me check it and try again.
Look at the coil and see if posts are marked. Positive ground car = positive side of coil wired toward points/distributor.
https://www.santaanitaas.org/wp-cont...pful-Tools.pdf Tom Endy |
If both spark plug electrodes are pointy then the polarity doesn't matter. The electrons will jump easier from a pointed electrode. The miniature spark plugs used on model airplane engine in the 1930's and 1940's have both electrodes pointed and the instructions written for how to hook up the coil say that the polarity doesn't matter. The polarity also determines which point has the metal eroded and which point has the metal deposited. This happens over time and happens more with a condensor that is not the correct microfarads. If the condensor is the right size there should not be any metal transfer between the points.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 07-07-2023 at 09:52 PM. |
Thanks everybody.
#9 | |
![]() Quote:
The condenser or capacitor's capacitance value it chosen to match the most efficient frequency of the coil's output capability during the induction cycle. It can vary a little and still function OK but it can't vary a lot or efficiency is degraded. A good condenser will almost eliminate any arcing across the points as they open. The smaller the amount of arcing, the longer the points will last. The little NuRex tool is a very handy tool for quick ignition system checks. It works for both polarity checks and just plain spark checks. Last edited by rotorwrench; 07-08-2023 at 08:51 AM. |
