Old 08-05-2015, 12:40 PM   #1
mrtexas
mrtexas's Avatar
Default Renner's Corner
Here is what you get from Renner's Corner. The round tag was on a zenith I bought on ebay, the first good running zenith I've bought. I've asked several carb "rebuilers" whether they used flow tested jets and the typical response is "don't need to I test them on my Model A." So much for good running carb by accident. I give up on zenith carbs without flow tested jets. Bad luck with those turned me to running Tillys.
mrtexas is offline   Reply With Quote
Old 08-05-2015, 12:44 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Renner's Corner
NO ONE should accept a "rebuilt" carb without flow tested jets!
Old 08-05-2015, 03:21 PM   #3
ericr
ericr's Avatar
I'm a little confused, are you saying Renner's flow-tested both, or that you bought a carb from them that was not, while an e-bay carb was, or what?
ericr is offline   Reply With Quote
Old 08-05-2015, 06:04 PM   #4
mrtexas
mrtexas's Avatar
I also bought an ebay carb that had a tag on it with the flow testing results(not by Renners Corner). Lucky me I didn't know it was flow tested when I bought it.
Old 08-05-2015, 06:05 PM   #5
mrtexas
mrtexas's Avatar
I also had one where the float valve stuck the first time I used it spilling gas all over the place.
Old 08-05-2015, 07:13 PM   #6
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
ANYTHING man made, "MAY" fail, sometime
I once baked a "SPOON" PIE!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-05-2015, 08:30 PM   #7
Mike V. Florida
Anything rebuilt is only as good as the parts that went into it.
Old 08-05-2015, 09:31 PM   #8
Mitch//pa
Anything rebuilt is only as good as the parts and workmanship that went into it.
Old 08-05-2015, 11:49 PM   #9
700rpm
700rpm's Avatar
I put Renner's jets in my Zenith and saw no difference in performance or mileage from my older jets. IE, about 15 mpg. Maybe my old ones were just fine, though they flow tested way out of specs.
Ray Horton, Portland, OR
Old 08-06-2015, 07:00 AM   #10
ericr
ericr's Avatar
I read once that the quality of gasoline in the Model "A" era was of lesser "quality" than today's, which means I guess that the octane was lower back then. does that translate into our needing smaller-sized jets for today's usage?
Old 08-06-2015, 08:34 AM   #11
1930artdeco
1930artdeco's Avatar
My car ran a whole lot better with their jets. Got better mpg and idle smoother.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 08-06-2015, 10:08 AM   #12
mrtexas
mrtexas's Avatar
Octane only has to do with the ability to resist knock. Nothing else, not energy content, starting ability, gas mileage etc.
Back in the 30s without lead gasoline octanes were 70-75 research octane. The octane of the gasoline was whatever it was in the crude cuts and some thermally cracked stocks. Today the regular unleaded is 90-92 research octane(92 research + 82 motor = 87 R+M/2) There was no motor octane back in the 30s. Today's refineries blend no crude cuts into gasoline. All the gasoline today is either catalytically cracked, reformed on platinum catalyst, or alkylated and almost totally desulfurized to 15ppm sulfur. None of those processes existed in the 30s.
Old 08-06-2015, 04:44 PM   #13
JD 1931
JD 1931's Avatar
Why not test the cap jet to see if it flows more that the comp jet??
JD 1931 is offline   Reply With Quote
Old 06-15-2023, 11:52 PM   #14
RENNERS CORNER
RENNERS CORNER's Avatar
So basically you're saying that jet flow doesn't matter because yours are way out of spec and perform the same as ones that are in spec. Makes you kind of wonder if carburetion/jetting isn't your problem? Hummm.
RENNERS CORNER is offline   Reply With Quote
Old 06-16-2023, 06:41 AM   #15
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
David, this post is nearly 8 years old now, ...and to the best of my recollection he no longer even owns a Model-A any longer.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-25-2023, 09:56 AM   #16
Canton_Model_A's
Canton_Model_A's's Avatar
I paid a visit to Mr. Renner, and yes, he does have a few Model-A's. So I have physically seen them and they are all in a state of restoration.
Canton_Model_A's is offline   Reply With Quote
Old 06-25-2023, 09:16 PM   #17
jeepguy1948
I believe David IS Mr. Renner
jeepguy1948 is offline   Reply With Quote
