Old 05-26-2023, 11:11 AM   #1
Mountain Dew
Mountain Dew's Avatar
Default Need help Identifying
What are these additional controls on the floorboard of this 1914 Runabout?
(I hope the images uploads.)
Mountain Dew is offline   Reply With Quote
Old 05-26-2023, 12:11 PM   #2
gz
gz's Avatar
Default Re: Need help Identifying
Warford or a similar transmission for the shifter. The buttons could be for a starter and/or exhaust whistle and/or cutout.
gz is offline   Reply With Quote
Old 05-26-2023, 02:23 PM   #3
Mountain Dew
I did a search for Warford and didn't find too much relating to Model T. Is Warford an overdrive?
Old 05-27-2023, 08:33 PM   #4
FRANK PKNY
FRANK PKNY's Avatar
Warford over drive, direct drive and under drive. Two speed rearend ? Photo of the underside behind the transmission and also the rear end. Then we can tell you what you have.
FRANK PKNY is offline   Reply With Quote
Old 06-14-2023, 01:05 PM   #5
Mountain Dew
I finally got my Model T delivered. Yep, it has a Warford transmission and exhaust whistle. I bought it out of an estate auction in Texas. Judging from the paperwork I received, it hasn't been licensed for 25 years. More pictures and plenty of questions will be coming. I'm a Model A guy from way back and this is my first Model T.
Old 06-15-2023, 06:53 PM   #6
Mountain Dew
After messing with the shift lever I've come to the conclusion that it's a two speed. Which position is direct and which is overdrive? My Model T has been sitting for a long time and I have yet to take on the task of starting it.
Old 06-16-2023, 10:52 AM   #7
rotorwrench
rotorwrench's Avatar
As far as I know, Warford made two types. The less desirable is an under drive/direct drive with a neutral in between so it's a two speed. The other is a 3-speed with under drive, direct drive, and overdrive.
The modern KC Warfords are 3-speeds. The shifter on the OP's car is very near the seat. I just wonder if it has room enough to shift?
Old 06-17-2023, 09:13 PM   #8
redmodelt
redmodelt's Avatar
Back might be direct. Get it running, drive it and find out! Search "MTFCA; Warford" There has been a ton of information post about the Warford's on the Model T Ford forums over the years.
Had the 3 speed. I very seldom used overdrive, so the under/direct would be fine, and is more than likely the one I will install. Except for the maybe ratios, would be about the same as a Ruckstell at a lower cost.
Old 06-19-2023, 06:05 PM   #9
Dan McEachern
If your T does not have accessory external brakes on the rear drums be very cautious driving your new car. Getting a Warford in neutral with out accessory brakes can become a life changing experience, as you loose all ability to stop the car .
Dan McEachern is offline   Reply With Quote
Old 06-19-2023, 07:21 PM   #10
Mountain Dew
Are these transmissions prone to jumping out of gear?
Old 06-20-2023, 09:06 AM   #11
redmodelt
redmodelt's Avatar
No not really, but if you miss a shift and get stuck in neutral, on a hill for example, the 8 inch brakes, which are just glorified parking brakes, aren't going to do jack poo stopping you from rolling.
Old 06-20-2023, 10:17 AM   #12
Mountain Dew
Thanks, I'm on the coast with no hills to speak of but I guess it would still be good to have Rocky Mountain brakes.
On another note, I pulled the floorboards and played with the shift lever. It appears that it is a 3 speed transmission. I did not see any support for the Warford Transmission that the MTFCA forum mentioned. I may need to do something about that too.
These are all things that I will get around too sometime.
Old 06-20-2023, 12:24 PM   #13
Royce P
Royce P's Avatar
This is the company that makes the Warford today:
http://www.laynemachine.com/Products.html
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 06-20-2023, 07:27 PM   #14
stevests
stevests's Avatar
If it is a 3 speed - forward right is low, straight back is direct and over left & back is O.D.
stevests is offline   Reply With Quote
