Old 04-06-2023, 07:59 PM   #1
PTaylorTBK
Default 53 Ranch Wagon floors
Does anyone have information on a place or person that can provide the full coverage floor mats for the 53 I'm working on? Originally the vehicle had one piece that covered the floor from under the front seat and up the fire wall. The other went from under the front seat to under the back seat.
Any suggestions you can give will be greatly appreciated.
PTaylorTBK is offline   Reply With Quote
Old 04-08-2023, 06:34 PM   #2
HOTRODPRIMER
HOTRODPRIMER's Avatar
Default Re: 53 Ranch Wagon floors
To the best of my knowledge no one make the front and rear floor pans, EMS makes very good floor patch panels. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 04-08-2023, 07:00 PM   #3
paul2748
paul2748's Avatar
Do you want floor mats or the carpets. For carpets try Stock Interior or Auto Custom Carpets (ACC Carpets)
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-09-2023, 08:19 AM   #4
38 coupe
38 coupe's Avatar
Noone makes floor mats like used at the factory. The original floor mats were one piece from the fire wall through to the back seat. I had a very rough 53 fordor sedan at one time with the remains of the factory floor mat and it was once piece. I asked a friend who remembers these cars from new and he verified this was what Ford did. If you bought replacement mats they came two, front and rear separate.
In the case of your wagon I suspect you will need to purchase the front mat that is available reproduction (not 100% copy of factory mat, but it is what you can get) and make your own rear seat mat.
Old 04-09-2023, 08:30 AM   #5
51504bat
51504bat's Avatar
Per a post from EMS on the 52-59 social board they will have rear floor patch panels by the end of April
https://www.jalopyjournal.com/forum/...-auto.1287859/
Also Classic Fabrication makes floor boards for 52-54 Fords. No idea about quality or fit, etc.
https://www.classicfabrication.com/
Old 05-05-2023, 12:06 PM   #6
PTaylorTBK
Thanks for the info. I will look into it.
Old 05-05-2023, 12:46 PM   #7
Zax40
Zax40's Avatar
Would the front piece for a wagon be different than a sedan or coupe?
I bought one from Carpenter for my 53 sedan:
Floor Mat - Rubber - 1952-54 Ford Car Part #: BA-7013000
For the rear I used a bulk roll and cut to fit:
https://www.amazon.com/gp/product/B0...TF8&th=1&psc=1
Zax40 is offline   Reply With Quote
Old 05-06-2023, 03:51 PM   #8
Bruce_MO
PTaylor,
I restored a ‘53 Ranch Wagon some time ago, and all I had was the rear mat. I was fortunate enough to be able to salvage it. It is simply a big moulded sheet of pebble grain rubber, with no other moulded-in features. So if you can find some pebble grain rollstock, you might be able with a heat gun and some weights to get a good reproduction. For the front mat, I used one I bought from Concourse Auto Parts. The only thing couldn’t replicate was the heavy vinyl over the rear wheel wells. I just painted them with rubberized paintable undercoating and then sprayed them with brown enamel. Finding the wood grain vinyl for the door panels and interior pieces took a lot of time. Happy to help with any other Ranch Wagon questions you might have.
Bruce
Bruce_MO is offline   Reply With Quote
Old 05-06-2023, 03:55 PM   #9
petehoovie
petehoovie's Avatar
Old 05-11-2023, 07:24 PM   #10
PTaylorTBK
Thanks Bruce. I likely will take you up on that offer.
Old 05-11-2023, 07:27 PM   #11
PTaylorTBK
I just received the front mat from Carpenter's today. Seems to fit in place, although I haven't worked to permanently install it yet. I'm going to try some of the suggestions
