Old 02-11-2024, 07:31 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Tire Inner Tube
Is the tube with the vulcanized metal valve stem still in stock anywhere? I need a 19" one in new or good used condition.
Bob Bidonde
Old 02-11-2024, 11:57 AM   #2
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: Tire Inner Tube
I'm not sure about that Bob, but I'd like to comment on a new set of 19" tubes I bought from Walt Bratton for our '30 Roadster, two years ago.
I was in the garage just yesterday. Car is stored in a heated garage.
I checked the air pressure and three were still on 35 pounds the other was at 33 pounds.
Two years and I've never put air in them
THANK YOU Bratton's for supplying good inner tubes!
Old 02-11-2024, 12:32 PM   #3
Shelbycsx
I have a 30 tudor thats been sitting since 1953 3 of the 4 tires still hold air after 71 years.
Shelbycsx is offline   Reply With Quote
Old 02-11-2024, 12:38 PM   #4
Shelbycsx
I believe this is the original roof.
Old 02-11-2024, 04:08 PM   #5
The Master Cylinder
The Master Cylinder's Avatar
You should try to save that air. Air from 1953 is heard to come.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 02-11-2024, 06:31 PM   #6
henry's 31
Hi Bob:
I have also used the inner tubes from Bratton's and I have had great luck with them. I always recommend them.
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 02-11-2024, 07:53 PM   #7
Shelbycsx
I have these tubes I believe they are from the 40's. Rubber is still soft.
Old 02-11-2024, 08:07 PM   #8
katy
katy's Avatar
If they're folded up I'd be suspect of them. Take one out of the box and check the folded corners, then inflate it and see.
Old 02-11-2024, 08:10 PM   #9
Shelbycsx
I did unfold them no cracks
Old 02-11-2024, 09:55 PM   #10
Joe K
Joe K's Avatar
Are bonded in metal stems available?
I though everyone "original" was going to the loose "clamp-in" stem - which uses the regular tube rubber stem which is cut off, leaves a hole, and then you stretch the hole around the T-shaped metal stem and clamp it in place?
Joe K
Shudda kept the horse.
Old 02-12-2024, 10:57 AM   #11
Bob Bidonde
My Victoria has rubber stem tubes modified to receive metal stems. Out of the 5 tubes I modified, one only holds air for a day, and the others need replenishing once per month. My coupe has rubber stem tubes and once per year they need replenishing because of the cold winter's cold weather.
I found that Snyder's has some 19" metal stem tubes in their show room for sale. These have stems that are vulcanized a bit offset, but I ordered 4 of them anyway.
Bob Bidonde
Old 02-12-2024, 11:03 AM   #12
rackops
rackops's Avatar
I bought six 19 inch tubes with the metal stems from Eckler's in October. I saw they had them in stock and jumped at the chance.
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" and a 1931 Victoria "Katie"
Former owner, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 02-13-2024, 02:39 PM   #13
Joe K
Joe K's Avatar
Currently showing IN STOCK for 19" Wheels. 21" are OUT OF STOCK.
https://www.ecklers.com/model-a-ford...8-22203-1.html
Joe K
