Old 03-18-2023, 05:49 PM   #1
Shoebox
Shoebox's Avatar
Default Oil Filter Canister Blues
I am having a heck of a time with something so common, the factory oil filter canister. Finishing my 8ba 276 engine build and I want an original oil filter. I took one I had and just sent it in for chroming,....only to realize upon it's return that it is one that mounts to head bolts, NOT what I wanted and a very expensive mistake (its for sale)! So I pick up another off that auction site and what's with this? See pic. This washer/plate thing at the top of the tube? I am thinking it is a remnant of a deceased oil filter, there are bits at the bottom that seem to indicate this, but boy this thing is really on there. Thought I'd post here before getting rough with removing it. Thanks.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 03-18-2023, 06:02 PM   #2
flatford8
flatford8's Avatar
Default Re: Oil Filter Canister Blues
I’ve got a bunch of those.....if that one doesn’t work.....send me a message........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 03-18-2023, 07:16 PM   #3
ford38v8
ford38v8's Avatar
Just a guess… that washer looks to be the same diameter as a toilet paper roll. Back in the day, toilet paper was used instead of a real oil filter in order to save money. Check it out and tell us if I win a chicken dinner!
Alan
Old 03-18-2023, 09:10 PM   #4
Shoebox
Shoebox's Avatar
Perhaps you're right, but the crumbling remaining bits seem to indicate a filter that disintigrated in the canister over time.
32 Ford roadster
39 Mercury Towncar
Old 03-18-2023, 09:39 PM   #5
tubman
tubman's Avatar
I'd be interested in the chromed filter. PM me if it's still available.
Old 03-19-2023, 04:11 AM   #6
aussie merc
aussie merc's Avatar
looks like there are more problems than just a stuck washer i would be check out the swap meets [P.S. take a spanner and open them up before you commit ]
aussie merc is offline   Reply With Quote
Old 03-19-2023, 06:40 AM   #7
corvette8n
corvette8n's Avatar
The replacement looks like something from a Ford 8N tractor.
Old 03-19-2023, 11:53 AM   #8
Shoebox
Shoebox's Avatar
What else are YOU seeing? Thanks.
32 Ford roadster
39 Mercury Towncar
Old 03-19-2023, 12:26 PM   #9
JayChicago
JayChicago's Avatar
One thing to check is: is the return path clear? Here is a pic of a common oil filter's return holes. Not sure if your filter cannister works the same way.
Old 03-19-2023, 02:46 PM   #10
19Fordy
19Fordy's Avatar
The chrome filter cannister will work if you use 3 of these head bolts with studs as shown in first photo and second photos. In the photo, the third bolt is hidden by the cannister.
Third photo shows cannister mounted to head using 3/8-16 bolts.
Old 03-19-2023, 04:20 PM   #11
Shoebox
Shoebox's Avatar
On my nice chrome canister the return holes are present as you depict, my recently acquired canister is too crusty at this time, to see them. That washer at the top of the tube does seem to be welded and I just cant understand how a filter could go on it.
32 Ford roadster
39 Mercury Towncar
Old 03-19-2023, 08:19 PM   #12
19Fordy
19Fordy's Avatar
Looks like that washer should be installed inside the top lid of the cannister as in photo #4. Filter can't be installed with that washer in the way. Here's another photo of a 1950-53 cannister. Don't forget to install a soft copper washer under the head of the lid bolt.
Old 03-20-2023, 09:17 AM   #13
Shoebox
Shoebox's Avatar
PM sent.
32 Ford roadster
39 Mercury Towncar
Old 03-20-2023, 03:53 PM   #14
Shoebox
Shoebox's Avatar
Well, just to conclude this episode, that was a washer rusted to the top of the tube. Took some heat and twisting and it came off. The inside is kinda crusty, going to blast the canister inside and out and see if this thing can be used once again. Thanks.
32 Ford roadster
39 Mercury Towncar
Old 03-20-2023, 04:00 PM   #15
cas3
I would soak it in Evaporust or, Rust 911 to ensure there is no sand left behind
Old 03-20-2023, 04:54 PM   #16
flatford8
flatford8's Avatar
One of these nifty little adapters would fix a problem like this ..........Mark
File Type: jpg 935BF489-9B5A-4962-B676-675329A06C86.jpg (12.0 KB, 81 views)
Old 03-20-2023, 09:37 PM   #17
19Fordy
19Fordy's Avatar
I made 2 of these adapters from 1/4 in. thick aluminum if anyone needs them.
Old 03-25-2023, 05:16 PM   #18
aussie merc
shoe box sorry so long to reply been away its what im not seeing no base washer and plenty of rust need to keep crap out not add it. Also some have the spring in the base not the lid. Thats why i always look before i pay
Old 03-26-2023, 10:09 AM   #19
Shoebox
Shoebox's Avatar
All true for sure. Even after soaking in Evaporust for days I'm not happy with the inside, as you say "need to keep crap out not add it". I am back to looking for a NICE filter canister that uses the 3 threaded bosses on head for mounting. Thanks.
32 Ford roadster
39 Mercury Towncar
Old 03-26-2023, 12:59 PM   #20
barnfind08
I have a nos one
barnfind08 is offline   Reply With Quote
