How can I take the Messko Radiator Cap off a Model A? I have tried, but do not want to break it. Is there a technique? See Pics. Thanks, Jim
It should release like other caps. Try to get it off using a strap wrench. One of mine is tough to remove and comes off fairly easy using the strap wrench.
Thanks. I have read that some of these caps have an anti theft set up on them. If this cap is set up that way, is there something else i need to do? I've tried turning it with a strap wrench, lifting while turning, still not coming off.
Thanks |
Does the cap turn? I put an O-ring on my quail and I have to press down as I turn the cap.
TOB |
Check if there is a small Allen bolt head on the backside of the cap. Some caps use that as an anti-theft device, as it's almost invisible unless you know what to look for.
Marshall |
I know the voices aren't real but damn they have some good ideas! ![]() |
Thanks for the help everybody. I finally got the radiator cap off, a little master blaster and some lite tapping on the cap and she came off. She was rusted to the filler neck.
Small victories are sometimes the greatest!
Being patient and careful generally pays off.
