Old 03-15-2023, 08:05 PM   #1
1crosscut
1crosscut's Avatar
Default Fulton Electric Fan
Is this fan an accessory for an A? I'm interested in installing a fan in my 29 AA truck.
If so how would it be mounted?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 03-15-2023, 08:42 PM   #2
mcgarrett
Default Re: Fulton Electric Fan
Looks like it could be used on a Model A and I assume it works on 6 volt. I suppose the most likely and beneficial place would be on top to the steering column - blowing right at the driver! The generator 3rd brush would need to be adjusted to supply enough juice to run it unless you replaced the generator with a 6 volt alternator, which would be the best option.
Old 03-16-2023, 09:07 AM   #3
KenBolton
I don’t know the name but have one mounted in my pickup. I mounted it in the upper front right hand corner similar to where they were on old school buses. This way they may be directed towards the windshield or the passengers. Mine needed the rotation reversed.
KenBolton is offline   Reply With Quote
Old 03-16-2023, 11:41 AM   #4
Gene F
Gene F's Avatar
Period correct might be a vacuum operated little fan.
Old 03-16-2023, 12:17 PM   #5
CarlG
CarlG's Avatar
Picture shows wires, so must be electric.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-16-2023, 12:32 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Fulton made numerous accessories for the Model A.
I have a Trico vacuum fan that I restored. I only install it for car shows to display era accessories.
Old 03-16-2023, 07:14 PM   #7
1crosscut
1crosscut's Avatar
Could very well be true but as I understand it the early cars didn't have the intake manifold tapped for a vacuum fitting and had electric wipers. I'm thinking that an electric fan would be more correct for my early 29 since it would have been made (maybe) before the vacuum wipers started to be standard equipment.
The person that has it will be getting me some better pictures of the mounting base so I can see if could be mounted on my truck.
I appreciate all of the input.
Old 03-16-2023, 08:35 PM   #8
Bigsnapper43
I have seen both vac and elect. They were pointed toward the winsheld as a defroster.
Bigsnapper43 is offline   Reply With Quote
