Old 08-10-2024, 09:27 PM   #1
john worden
john worden's Avatar
Default Helicoil issue in head stud hole.
Attempting to install Helicoil in head stud location. After drilling with the supplied drill, the supplied threading tap will not engage to start cutting threads. The block is in the car and I lubricated the drill and tap with cutting oil. We tapped lightly on the tap while turning it, but it will not engage. Any thoughts appreciated. Thanks. John
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 08-10-2024, 09:40 PM   #2
Charlie Stephens
Default Re: Helicoil issue in head stud hole.
Would it help to chamfer the hole?
Charlie Stephens
Old 08-10-2024, 10:01 PM   #3
Synchro909
Synchro909's Avatar
I think a steady downwards pressure while you turn the tap would be better than "tapping the tap". If you chamfer the top of the hole, don't go overboard. Chamfer a little, try it and if you don't get anywhere, chamfer it a little more till you succeed. Personally though, I wouldn't chamfer it.
PS. It is important that the drill and tap are kept perpendicular tot he top of the block or the stud will not line up with its hole in the head.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 08-10-2024, 10:17 PM   #4
johnneilson
Typically machining cast iron is done dry, no lube
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 08-10-2024, 11:50 PM   #5
Y-Blockhead
Y-Blockhead's Avatar
I agree. I use a tap guide similar to this one to ensure the tap is pertpendicular to the top of the block (or whatever you are tapping https://www.amazon.com/GATOR-TOOLS-V...3351856&sr=8-5
Old 08-11-2024, 01:39 AM   #6
Bruce of MN
Bruce of MN's Avatar
This was my experience:
https://www.fordbarn.com/forum/showt...rt#post1997462
Old 08-11-2024, 06:17 AM   #7
nkaminar
nkaminar's Avatar
Synchro has a very important point. The Helicoil must be in the proper location and perpendicular to the block. I have used an old head for this, bolting it to the block and enlarging the hole where the Helicoil tap is used just enough. The head can still be used on an engine with the enlarged hole, if necessary.
I agree that a steady strong pressure is needed to start the tap. I also agree that the hole should be tapped dry. Tap a little then back out a half turn to clear the chips, then continue. Repeat to back out as you tap to continue to clear the chips.
Old 08-11-2024, 10:30 AM   #8
Terry Burtz, Calif
Helicoil taps come in plug and bottoming styles.
If you are trying to start a threaded hole with a bottoming style tap, it is very difficult.
Terry Burtz, Calif is offline   Reply With Quote
Old 08-11-2024, 10:42 AM   #9
john worden
Charlie Stephens
Worth considering. Thanks.
Old 08-11-2024, 10:46 AM   #10
john worden
We did make and use a guide for that purpose. Thanks.
Old 08-11-2024, 10:48 AM   #11
john worden
We will try that. Thanks.
Old 08-11-2024, 10:49 AM   #12
john worden
Thank you. John
Old 08-11-2024, 10:54 AM   #13
john worden
Thank you. This looks promising. John
Old 08-11-2024, 10:55 AM   #14
john worden
Thank you. John
Old 08-11-2024, 12:10 PM   #15
Phil Brown
Phil Brown's Avatar
Agreed with Terry, trying to start a bottoming tap in a freshly drilled hole is tough to do. might also check that the drill is the correct size for your Helicoil, even if it came as a "kit" things happen in packaging
Phil Brown is offline   Reply With Quote
Old 08-11-2024, 12:23 PM   #16
john worden
Will check again. I know it isn't a bottoming tap. Thanks. John
