Old 07-03-2022, 11:13 PM   #1
ford nut
ford nut's Avatar
Default 1936 coupe, is this factory?
i'm getting my coupe ready for paint, so i've been fixing all the things that can happen to a car of this age. i'll be posting some pics of the left and right lower cowl repair that are finally done later.
the car had been up against the wall for months while i was working on the driver side cowl, so i haden't see the passenger side for some time.
i moved the car so i could go over areas to recoat epoxy primer, and found a strange slot hole i can't remember ever seeing in the passenger door jamb.
if i had seen it, i would have done the repair. i'll post some pics, and you can tell me what you think. . . .thanks, kurt.
ford nut is offline   Reply With Quote
Old 07-04-2022, 03:14 AM   #2
BLACKNRED
BLACKNRED's Avatar
Default Re: 1936 coupe, is this factory?
looks like a chisel hole to me
BLACKNRED is offline   Reply With Quote
Old 07-04-2022, 05:29 AM   #3
mercman from oz
mercman from oz's Avatar
Non factory hole on 1936 Ford Coupe needs repair before paint.
Old 07-04-2022, 06:10 AM   #4
ford nut
ford nut's Avatar
i think blacknred is right. it does look like a chisel or something similar was used. i got behind it and saw the door post had a exit hole coming through, also rectangular. the door post is a hallow "box" about 1-1/8" thick, exit hole is smaller telling me it was tapered like a sword of something. they must have had to use a hammer to do the damage as the metal is bent/folder outward. anyway, it looks like 3 or 4 hours to make it go away.
thank you for the replies, kurt.
Old 07-04-2022, 06:14 AM   #5
sugarmaker
sugarmaker's Avatar
We need some pictures of the car and the finished work. Details!
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 07-04-2022, 06:20 AM   #6
ford nut
ford nut's Avatar
i can do that. it's not stock though. . .some don't like that. . . .
Old 07-04-2022, 08:37 AM   #7
Zeke3
Zeke3's Avatar
I have some major repair work needed on the lower cowls of my 1937. I would be interested in your repairs it that area.
Zeke3 is offline   Reply With Quote
Old 07-04-2022, 09:17 AM   #8
TJ
TJ's Avatar
Is that hole in the back door jamb or in the cowl? If it's in the back door jamb it doesn't belong there. If it's in the cowl I don't see any place for the door hinges to mount?
Old 07-04-2022, 09:25 PM   #9
TagMan
Nothing like that on my 36 3w coupe.
TagMan is offline   Reply With Quote
Old 07-05-2022, 08:43 AM   #10
uncle buck
uncle buck's Avatar
It is on the B pillar / back door jamb from what I can see. Unfortunately, it does not belong.
uncle buck is offline   Reply With Quote
Old 07-05-2022, 03:22 PM   #11
ford nut
ford nut's Avatar
it got it fixed yesterday. i'll post some pics after i grind the welds today.
Old 07-05-2022, 06:46 PM   #12
ford nut
ford nut's Avatar
alright. the mess is cleaned up, i took a few photos and now can get back to doing some bodywork. i still can't believe i didn't remember this gash. i will be posting some lower cowl repair photos and some firewall repair photos too. what it takes to get these old car in shape is nuts. they go through hell before we even buy them.
anyway, here's the photos of this repair. . . .
Old 07-05-2022, 07:55 PM   #13
cas3
Looks good !
Old 07-05-2022, 08:36 PM   #14
Zeke3
Zeke3's Avatar
Great looking repairs. I can't imagine what the reason was for making those holes in the first place, but it looks good now.
Old 07-06-2022, 06:26 AM   #15
mercman from oz
Looking good. Congratulations on a job well done.
Old 07-06-2022, 06:50 AM   #16
ford nut
ford nut's Avatar
don't be lookin' for my mistakes . . .kidding. car looks like a garbage can inside.
Old 07-06-2022, 07:09 AM   #17
ford nut
ford nut's Avatar
i'll put up a preview of the driver side lower cowl repair . . .
Old 07-07-2022, 05:28 AM   #18
mercman from oz
From Rusted to Repaired. Great workmanship. Congratulations for a job well done.
Old 07-07-2022, 01:28 PM   #19
TJ
TJ's Avatar
Nice work.
Old 01-03-2023, 10:25 PM   #20
ford nut
ford nut's Avatar
totally forgot about the lower cowl repair photos. so sorry. will get them up very soon, kurt.
