Old 01-10-2023, 11:25 AM   #1
wcmill
Default 12 volt aux battery grounded to frame??
Hi guys, this is my first post and am happy to be aboard……WHAT A FANTASTIC SITE!!
I finally bought my first Model A about a week ago. Have been a dedicated muscle car guy (still am) but love the A…..so simple.
So first of I’m sure many questions:
For clarity my car is a 31 deluxe roadster. It was fully restored about 9 years ago, driven for a few years then stored. I’m in the process of changing fluids, timing, gas tank rust removal, etc. the previous owner installed a small hobby battery to run the 12 volt signal lights that were installed. For whatever reason he grounded the neg terminal to the firewall, and installed an inline switch on that line.
The car itself is the original 6 volt positive ground..
Would this not create havoc or issues with the ignition or for that matter anything else that’s operated by the car on 6 volts?
So you have a big 6 volt car battery grounded positive…..then a smaller 12 volt grounded negative…but to the same place (the frame). Would they not be in conflict with each other in some way??
I haven’t started the car yet….however the signal lights do work fine.
wcmill is offline   Reply With Quote
Old 01-10-2023, 11:40 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: 12 volt aux battery grounded to frame??
as long as the 6V and the 12V wires never connect to each other neither know about the other
My MG had + ground, the radio had - ground through a converter, the car and the radio shared the same ground, everything was fine until a speaker grounded itself, then the smoke came out of the speaker.
Old 01-10-2023, 11:50 AM   #3
rotorwrench
rotorwrench's Avatar
It may not affect the cars normal system just by using the same ground plane. The polarity won't be an issue since the power side of the circuit is not shared with the normal system. A good indication of problems would be to watch the amp meter when this 12-volt system is in operation. It probably should have been isolated but it may have no affect unless the another electrical device is inergized too close the the system while in operation.
A lot of reproduction lighting for the model A cars is going toward LED lights now days and they aren't as voltage sensitive as incandescent lights. Some of this stuff may not have been as available 9 years ago. A person might think about converting it to LED with 6-volt positive ground circuitry. This takes a lot of load off the original system since LEDs use only a fraction of the amperage of the old incandescent bulbs. The wiring can remain the same but bulbs and possibly the signal stat would be the big change. Some signal stats are electronic and some are bi-metallic thermal breaker activated. The ones with the thermal breaker sometimes need resistors to make them work correctly. The electronic or electro-mechanical types will usually work with low current draw systems.
Old 01-10-2023, 11:59 AM   #4
wcmill
Thanks for the quick reply fellas! I guess I’ll wait and see what happens once I get the car running.
I like the LED idea.
Old 01-10-2023, 08:03 PM   #5
Smokedtires
Smokedtires's Avatar
Welcome, I too come from muscle cars, still have a couple. I love driving my 30 Roadster Deluxe which sounds very similar to yours, restored then put away. I went through timing, spark plug gapping, re-torquing everything, etc. This is a great site and YouTube have been very helpful in learning about the Model A world.
Smokedtires is offline   Reply With Quote
Old 01-10-2023, 08:25 PM   #6
wcmill
I totally agree.
Its becoming a bit of an addiction🫤
Old 01-10-2023, 08:42 PM   #7
McMimmcs
McMimmcs's Avatar
Welcome to the Barn. Love to see pictures of your new treasure !
Wayne
Old 01-11-2023, 11:34 AM   #8
katy
katy's Avatar
Depending on what type of signal lights and controls are on the car it might be wise to convert the signal lights to 6 volt positive ground.
Old 01-12-2023, 09:57 AM   #9
captndan
captndan's Avatar
Correct....But make up your mind and go all 12v or all 6v.. A combination is just inviting trouble.
captndan is offline   Reply With Quote
Old 01-12-2023, 11:22 AM   #10
ed thibodeau
I use a 12V dry cell for my CB, radio and backup camera. They are not expensive
and seem to last a long time
ed thibodeau is offline   Reply With Quote
Old 01-12-2023, 01:45 PM   #11
airjam
I am currently restoring my 6V Tudor + ground.
I will be experimenting using a 6V to 12V electronic converter and use the frame for ground on the 12V circuit for power to turn signals and park and brake lights.
I do not anticipate any problems with the setup and the 12V will not be dependent on a separate battery so no need to charge a second battery.
Starter / Headlights / Horn / Alternator / Ignition will remain 6V.
10AMP version on Amazon search for DIGITEN DC 6V 5-11V to 12V
airjam is offline   Reply With Quote
Old 01-12-2023, 02:14 PM   #12
Bill G
Bill G's Avatar
.... but why not just use 6 volt turn signal, park and brake lights? They work just as well as 12v. Also, be careful with that inverter.
I think the inverters you are looking at use separate common (ground) circuits. In other words the positive ground input cannot be tied to the negative ground output. If that is the case, you would need to run an isolated negative to the lights and not touch the body of the car.
I have one of those to drive a cigarette lighter socket. I cannot let the negative output touch the metal car body.
Old 01-12-2023, 02:33 PM   #13
airjam
Thanks for that information. I was concerned about common ground. I will have to check into that. Want the convenience of having a 12V circuit to run 12V accessories. I am not a purist and plan on common 12V turn signals which are much cheaper than the 6V aftermarket Model A style.
