Old 10-12-2022, 10:57 AM   #1
littlelake
Default B model distributor
Does anybody know of a source for an overhaul kit for a B distributor? I found a good candidate for swapping the stock unit on my '30 Tudor.
littlelake is offline   Reply With Quote
Old 10-12-2022, 11:18 AM   #2
Charlie Stephens
Default Re: B model distributor
Renner's Corner used to be the "go to" place and I would assume they still are: (734) 428-8424. Remember when timing it the timing gear has the timing pin in a slightly different location.
Charlie Stephens
Old 10-12-2022, 11:19 AM   #3
Bob C
X2 on Renner's Corner. http://www.rennerscorner.com/distributor.html
Old 10-12-2022, 03:38 PM   #4
garyjohn
Yep, that's where I get my b dist. parts
garyjohn is offline   Reply With Quote
Old 10-12-2022, 04:27 PM   #5
Synchro909
Synchro909's Avatar
IMO, the only place for a B distributor is in the trash bin. They are junk and I believe they are the reason so many B blocks end up cracked. They do not advance reliably and as we all know, an engine running retarded will run hot and that is what causes the cracks. I've heard it said that a thinner casting is responsible and I hold my opinion on that. Thin casting or not, when the distributor doesn't advance properly, the end result is a cracked block.
I have 3 of them and I can't see any reason to turn the place upside down to find them.
My advice is either use an A distributor or buy a later one that works. It'll be cheaper in the long run.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 10-12-2022, 06:04 PM   #6
Bob-A
Bob-A's Avatar
Thumbs up Re: B model distributor
I rebuilt a "B" dizzy using Renner's Corner parts. Good parts and great people to deal with. Unfortunately, I could never find the short in the distributor. I've never considered myself a mechanic, but a good parts changer. I went back to the original later '31 dizzy which I also did some parts exchanging on it and it works fine.
Bob-A
"Skirts are for Women and not Car Fenders"
Bob-A is offline   Reply With Quote
