Old 09-22-2022, 04:24 PM   #1
Merc Cruzer
Merc Cruzer's Avatar
Default Cigar lighter fuse 1953 Mercury
My "cigar lighter" did not work, so I decided to take the time to look into it. I did a continuity test and it was an open circuit, when the lighter was pushed in. I took off the "cigar lighter fuse" and found that to be the issue. Since I had another one that tested good, I decided to take the old one apart, to see how it was constructed.
I did't fine an actual fuse, or for that mater, anything that would act like a fuse. Was this one just defective during construction, or was there an actual fuse inside at one time?
Merc Cruzer is offline   Reply With Quote
Old 09-22-2022, 05:57 PM   #2
Bob C
Default Re: Cigar lighter fuse 1953 Mercury
Don't know where the fuse is located but the part number is FAA 14429-A Fuse
assembly (cigar lighter) Did a search and found this picture.
Bob C is online now   Reply With Quote
Old 09-23-2022, 09:55 AM   #3
rotorwrench
rotorwrench's Avatar
It looks like all that is left is a spring. Fuses can literally vaporize when they blow. The spring was likely there to insure contact of the fusible material between one side and the other. The spring is too large on the one end to even make contact. This is only my own opinion so I could be wrong, It wouldn't be the first time and likely wouldn't be the last either.
Old 09-23-2022, 01:15 PM   #4
Merc Cruzer
The interesting thing is , there is no fuse rating on the housing, or it appears, even on a new one, in the original package. The fuse would be real tiny, to fit inside the housing, so I doubt that will be an option, to refurbish it. So much for reverse engineering.
Old 09-23-2022, 04:21 PM   #5
rich b
rich b's Avatar
The whole assy is the fuse; when it blows you replace it with another one. Like in the old days with screw in house fuses or cartridge fuses on electrical gear.
Old 09-23-2022, 06:00 PM   #6
Merc Cruzer
Agreed, and that is what I did, but I was trying to see how the "fuse" was constructed. As rotorwrench said in his post, it may have just vaporized.
