Old 08-25-2022, 09:06 PM   #1
CA Victoria
CA Victoria's Avatar
Default 1935 Pickup Fender Support
My pickup didn’t come with the front fender supports. I have collected a couple of different styles........The two longer supports in the photo are closest to fitting but fall short by about 1/2” of making the distance between the frame and the inner fender.
If these are the correct ones I will put them in the stretcher.
What does the brace with the carriage bolt fit?
File Type: jpg 75041916-7B58-4C34-810C-EBFB320CA91B.jpg (45.3 KB, 21 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 08-29-2022, 10:55 AM   #2
TLOHM
Default Re: 1935 Pickup Fender Support
Here's a photo of the secondary front fender supports for the 1936 Pickup, that I'm working on. From end-to-end, the measure about 10-3/4". The should be the same as the 1935 Ford.
TLOHM is offline   Reply With Quote
